Neuspeed lower tie-bar removal questions
Old Dec 28, 2003 | 03:52 PM
bfitz's Avatar
Default Neuspeed lower tie-bar removal questions
I recently bought an '01 PY ITR, and I'm getting it ready for stock-class SCCA autox. It has a Neuspeed lower tie bar (in addition to the stock bar) that I need to remove, and I was wondering if anyone could tell me whether or not the Neuspeed bar came with longer bolts. If so, I'll need to get some stock-length bolts before I start ripping things apart.
Also, there are a couple brackets for, I believe, the ABS wheel sensor wires that had to be slightly relocated to install the bar (now wire-tied to the bar), and I need to replace the missing bolts. Does anyone know the bolt size off-hand?
Thanks,
Brian Fitzpatrick
'01 PY ITR #1014
Old Dec 28, 2003 | 05:58 PM
Gee3's Avatar
From: Formerly of SF moved to DFW and now back in SF, CA, USA
Default Re: Neuspeed lower tie-bar removal questions (bfitz)
Yes, the Neuspeed bar did come with longer bolts. As for the size of the bolts on the ABs brackets, not sure but they are a pretty common size. I think I used a 8mm socket to un-install mine on my GSR.
Old Dec 28, 2003 | 06:56 PM
bfitz's Avatar
Thanks! Anyone know the specifics of the stock bolts - size, thread, length?
Old Dec 28, 2003 | 07:34 PM
SkyeC's Avatar
Boba Connoisseur
25 Year Member
I'd go ahead and get the OEM bolts from the dealer - they have pointed ends and make R/Ring them so much easier than standard flat ended bolts. Pretty sure you can't get something like that at a bolt/nut store.
Old Dec 28, 2003 | 07:39 PM
bfitz's Avatar
Thanks for the tip. I'll do that and pick up the bracket bolts at the same time.
Old Dec 28, 2003 | 08:27 PM
bfitz's Avatar
Anyone have the part numbers for these bolts?
I'm looking on http://www.acuraautomotiveparts.org, but the parts diagram image is missing for the "REAR LOWER ARM" section, which I believe is what I need.
mynameizstitch
Suspension & Brakes
Mar 15, 2009 04:04 PM
supracrx
Suspension & Brakes
Dec 7, 2007 07:39 AM
jeremy.
Jan 28, 2005 09:30 AM
MestizoRacer310
Jun 9, 2004 06:16 PM
