Civic and Del sol Steering??
Old Dec 28, 2003 | 03:04 PM
SOHC_DK.'s Avatar
Default Civic and Del sol Steering??
Is there any difference on the Del Sol Power steering (B16) and the EG Power steering (d16Z6)???????
thanks..
M. Nielsen
Old Dec 28, 2003 | 11:26 PM
SOHC_DK.'s Avatar
Default Re: Civic and Del sol Steering?? (SOHC_DK.)
bump..
Old Dec 29, 2003 | 05:05 AM
Solracer's Avatar
Since no One answered I believe that the Del Sol B16 Rack is a quick ration rack and the same as a GSR's. Where the D series rack are a slower ratio.
Old Dec 29, 2003 | 07:20 AM
Solracer's Avatar
Default Re: Civic and Del sol Steering?? (Kikomon)
Yes If my memory is correct the GSR and Del Sol VTEC Rack are the same and they are a faster ratio than the Civic EX Del Sol SI
Old Dec 29, 2003 | 07:40 AM
Spraying93's Avatar
Default Re: Civic and Del sol Steering?? (Solracer)
i also have a question about steering...when i am sitting still i can wiggle my steering wheel back and forth and it is making like a knocking sound...it is coming from my box...i have also done this to three other civic's and they were all 99-00 civic si. they all did it is there somthing to worry about or what?93hb si
Old Dec 29, 2003 | 08:45 AM
day1si's Avatar
YES.
Although it depends on the model.
The VTEC Sols have a rotary power rack and pinion steering setup, although the rest are all the same as the civics.
The actual rack ratios are a little different. I have #'s off the top of my head, but I'm not sure they are right, so I will wait until I see my helms manual before posting. Although I currently am not in possesion of my manual, so it could be a day or 2.
Ratios are
VTEC~
Civic/ S, SI Sol~
Old Jan 4, 2004 | 01:35 PM
day1si's Avatar
Default Re: Civic and Del sol Steering?? (day1si)
DOHC VTEC ratios~16.0
S and Si ratios~ 17.5
Manual all civics/del sol~19.0
4 way valve syatem is S, Si.
Rotary valve type is VTEC.
JaGuAr81
Jun 8, 2022 04:05 PM
MajorPayne
May 12, 2005 07:33 PM
