QUICK Q
Old Dec 28, 2003 | 11:13 AM
SIcoup's Avatar
Default QUICK Q
How do you remove the door paneling in a 94 ex coup si. There is only one screw i can find which i took out and im holding back from jus pulling the door apart. Need to install some new speakers while its still warm outside please help :D
Old Dec 28, 2003 | 11:42 AM
solsteeler's Avatar
Default Re: QUICK Q (SIcoup)
The panel is held on by plastic clips that run around the panel. You can use a flathead screw driver with a rag around it to get the panel off. Just insert the screw driver between the door and panel, then just gently pry it away. Make sure remove all the screws first.
Old Dec 28, 2003 | 06:22 PM
delsol3982's Avatar
Default Re: QUICK Q (solsteeler)
do it the right way....use a panel popper, found at any local auto store. a screw driver will work, however, it can a. damage the panel, and b. break the clips. there is nothng worse then closing ur door with broken clips and the panel rattleing around on the inside.
themurrell
Feb 21, 2007 08:32 PM
Toroke
Apr 14, 2006 03:55 PM
JDMEK206
Jun 27, 2003 02:36 AM
babyviper97
Jan 10, 2003 05:14 AM
teg95
May 22, 2002 01:16 PM
