6 cyl.
Old Sep 24, 2001 | 07:10 PM
BM710HS's Avatar
New User
Default 6 cyl. HYBRID
What would the feasability of putting a TL type S engine into a '94 accord? Would there be any additional benefits, or negatives, over a H22a? Also, seeing as the 4th gen. accords had 2.7L V6, and the type S is a 3.2L, would that be detrimental to the balance of the car? Maintaining balance is probably my top priority.
[Modified by BM710HS, 10:02 PM 9/25/2001]
Old Sep 26, 2001 | 10:24 AM
GraphiteAccord's Avatar
Default Re: 6 cyl. HYBRID (BM710HS)
it could be done for sure. i'm sure the mounts are the same too. wiring may be a bitch, along with the immobilizer in CL-S and TL-S ecu's. could convert the motor to OBD1, and then get a chipped Accord ecu, but i'm not sure on the wiring harness. Your best bet? i would recommend buying a prelude or a 4cyl. accord 5 speed and then doing a swap. its hard to deal with something that no one has really done a lot. I'm sure someone out there has probly done this, but what are the chances that they'll have all the info?
Old Sep 26, 2001 | 10:40 AM
SOHCArchangel's Avatar
Default Re: 6 cyl. HYBRID (GraphiteAccord)
h22, and turbo is a less of a headache
Old Sep 26, 2001 | 02:06 PM
Nick M's Avatar
Default Re: 6 cyl. HYBRID (SOHCkordVTEC)
The 95-97 Accord V6s had to extend the 4cyl front end didnt they? to fit the V6 in there? Keep that in mind if u try this swap. Its not going to fit into the engine bay.
PWRDbyHseries
Nov 14, 2006 09:33 PM
KingJeff
May 31, 2005 11:15 AM
jbonehead85
Aug 10, 2004 01:50 PM
Sleeping4drLS
Feb 10, 2003 09:18 AM
ace1875
Jan 2, 2003 10:05 PM
