where 2 buy a throttle body gasket?????
Old Dec 28, 2003 | 07:24 AM
1boostedcivic's Avatar
Default where 2 buy a throttle body gasket?????
Hey guys, just recieved my new skunk2 intake manifold. I'll be using it on a d16z6 with a stock throttle body. I just picked up my intake manifold gasket at disc Auto Parts, but they didn't carry the tb gasket. Do you know anywhere I can find these online? and is there anymore gaskets I need for the swap?
Your help is well appreciated,
thanx
Old Dec 28, 2003 | 07:30 AM
BMac86's Avatar
Default Re: where 2 buy a throttle body gasket????? (1zexxedcivic)
Go to your local Honda dealer. I got mine from an Acura site online because I have a GSR TB on my Skunk2 IM for my d16y8.
Edit: You will probably need to replace a few vacuum tubes with longer ones. I had to replace two or three vacuum tubes and a coolant hose because they were too short. You are going to have a huge struggle with getting the real big coolant tube onto the IM bung, so put some liquid soap on the bung and work at it. Also, if you have an EG(92-95) Civic, then you're prolly also going to need some beefier motor mount bushings, as your IM is going to bang against your brake equalizer valve or whatever it's called back there on the firewall. Also, if you have a cold air intake, it may not clear your fuel filter, so you may have to cut it and put in a rubber connector so the intake can move a little.
Good luck, I can take pics of mine or wlak you through it if you need help.
Old Dec 28, 2003 | 09:07 AM
TeamNextGenChris's Avatar
here ya go
16176-P06-A01 GASKET, THROTTLE BODY (ISHINO GASKET) $0.74
http://www.slhondaparts.com/br...+BODY
chris
Old Dec 28, 2003 | 11:03 AM
thanx guys for your help, Ill place an order today
Old Dec 28, 2003 | 12:27 PM
Jimmy's Avatar
Global Moderator
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 1zexxedcivic &raquo;</TD></TR><TR><TD CLASS="quote">thanx guys for your help, Ill place an order today</TD></TR></TABLE>
Are you getting it from honda??
Old Dec 28, 2003 | 01:50 PM
GRAVEDIGGER's Avatar
Default Re: where 2 buy a throttle body gasket????? (USDMDC2)
its only like $7 from honda, thats what i would get.
Old Dec 29, 2003 | 10:56 AM
JforJonathan's Avatar
Default Re: where 2 buy a throttle body gasket????? (GRAVEDIGGER)
dealer
Moonraker09
Feb 13, 2013 08:50 PM
Fo-Do Fanatic
Feb 14, 2011 10:27 AM
Th3savinday
Apr 12, 2007 09:32 AM
bootlegtrader
Feb 3, 2006 07:17 PM
Peter Langly
Jun 18, 2004 03:19 PM
