94 Accord Front End Noise
Old Dec 28, 2003 | 04:00 AM
erchavez's Avatar
Default 94 Accord Front End Noise
I have an annoying noise coming fom my frontend that sounds like a rubber bushing gone bad. It only occurs when the outside temp drops below 45 degrees. Could this be an upper control arm bushing that I am hearing? Any help would be appreciated.
Old Dec 28, 2003 | 09:56 AM
Riceburner247's Avatar
Default Re: 94 Accord Front End Noise (erchavez)
(we need a little more info than that)
Old Dec 28, 2003 | 12:16 PM
jwogen1's Avatar
try spraying some litiuim grease on the bushing and see if that helps
Old Dec 28, 2003 | 03:46 PM
StyLz's Avatar
If it's the same noise I'm thinking of... a small squeek-like noise when you go over bumps. Then it probably is yes. I've got the same problem but it's not a big worry.
Old Dec 28, 2003 | 08:33 PM
DragonTLS's Avatar
sounds like you have worn shocks,
Old Dec 29, 2003 | 05:19 AM
erchavez's Avatar
Default Re: 94 Accord Front End Noise (StyLz)
Your right its not a big worry and its pretty much as you described. I'm just tired of listening to it.
Shocks are new so I have eliminated that source. Thanks for the help
Old Dec 29, 2003 | 10:15 AM
The Maryland Truth's Avatar
Try white lithium grease on the upped and lower balljoint and also the swaybar bushings.
Old Dec 30, 2003 | 01:14 PM
adio's Avatar
Default Re: 94 Accord Front End Noise (The Maryland Truth)
if its more of a knocking and you can feel it through the floor then its most likely a balljoint.
Old Dec 30, 2003 | 05:39 PM
LookingForVTEC's Avatar
Default Re: 94 Accord Front End Noise (adio)
I have noticed that shocks make more noise when there are cold too. You shocks may be worn out.
Old Dec 31, 2003 | 08:53 AM
JLockheed's Avatar
Default Re: 94 Accord Front End Noise (LookingForVTEC)
Mine dose it too when its really cold....
rEnZ94tEgGy
Suspension & Brakes
Apr 27, 2008 11:58 AM
dopefeen
Apr 3, 2007 04:04 PM
puertoroc7976
Mar 12, 2007 04:01 AM
zither
Aug 4, 2005 09:37 PM
