Lowering My EP3...but a few questions..
Old Dec 27, 2003 | 10:31 PM
SiRocket02's Avatar
Default Lowering My EP3...but a few questions..
Im thinking of buying the Eibach Sportline springs for my '02 Civic Si. I was wondering if the F 1.4" R 1.5" drop would need camber correction, and if so where I could find one. Also, any comments on these springs, or other better ones and where to find them would be nice to. I'd appreciate your help!
Old Dec 28, 2003 | 07:20 AM
crxagogo's Avatar
Default Re: Lowering My EP3...but a few questions.. (SiRocket02)
...when lowering, you can never go wrong with a camber kit but with the Sportlines it is not something you "have" to have. The pro-kit would be a better choice if you are worried about camber (but I'm biased because that's what I have) and it still rides like stock. Plus you can't really go wrong with eibach IMHO so either would fit the bill.
Old Dec 28, 2003 | 08:44 AM
ITR_1211's Avatar
Default Re: Lowering My EP3...but a few questions.. (crxagogo)
Its always better to have the camber kit on. With lowering springs though, you can get away with them.
With coilovers, camber kits is a must.
Old Dec 28, 2003 | 09:06 AM
Jim Truett's Avatar
You will not need camber bolts in the front. The camber will end up at about -.5 degrees. For the rear you will end up at about -1.3 to -1.5 degrees. You may want to consider a camber kit for the rear. An alignment is definitely necessary though, as the track angle will be off. Without an alignment you will have serious rear tire wear issues.
rycrkt
Suspension & Brakes
Mar 11, 2011 03:47 PM
JDM_nUt
Feb 17, 2010 10:33 PM
smirff07
Honda Fit
Sep 5, 2007 05:56 AM
GUNNER666
Jul 28, 2004 08:26 AM
