Yellow vs Illumina vs AGX
Do the overall value of each offset the cost
Koni Yellows- $539
Tokico Illuminas - $479
KYB AGX - 359
Yellows are the best, but the min/max range of the damper adj's is apparently larger on teh AGX than the illumina....also which ones would pair up w/ GC coilovers best????
Koni Yellows- $539
KYB AGX - 359
I have never heard anything really bad about AGX. Yellows are badass if you have the money but you might as well get Tein SS (by the time you get the yellows + springs it will add up to about some SS)
From my POV...
Koni- pro=excellent performance, good value if you track your car(consider revalve, rebuilt,etc)
con=pricy
AGX-Pro=entry level adjustable shock, fair price
con=doesnt work too well with accord body(weight?), not availble for 6th and 7th gen
Tokico illumina-Pro=entry level adjustable shock, cost little more than agx, alot cheaper if you buy a tokico shock/spring package
tokico HP blue Pro=cheap as hell(280 dollar), a great improve over stock shock especailly with mild drop
con=it's only 75 buck per shock, you do the math
I would do illumia over agx, that's if yellow too rich for your blood
con=pricy
RacingShoeBox
Suspension & Brakes
21
Oct 24, 2005 09:28 PM
Benj
May 7, 2003 08:51 AM
my Illumina coilovers
