Polyurethane Bushings Question
Old Dec 27, 2003 | 07:11 PM
jwogen1's Avatar
Default Polyurethane Bushings Question
Putting bushings on a 94 Accord, only have ball joint boot set, front lower C-arm set, front tie rod end set, and front strut rod set. What else would anyone recommend? Didnt get the whole set. Thanks in advance.
Old Dec 27, 2003 | 07:32 PM
Riceburner247's Avatar
Default Re: Polyurethane Bushings Question (jwogen1)
sway bar, control arms, engine mounts, etc. I would buy the rest of the set.
Old Dec 27, 2003 | 07:36 PM
jwogen1's Avatar
Default Re: Polyurethane Bushings Question (riceburner247)
wondering if i should send what i have back and get the whole set including rear control arms? I'm mostly just concerned with suspension--not necessarily engine mount and s$*%.
Old Dec 27, 2003 | 07:42 PM
jwogen1's Avatar
what kind of install time/cost are we looking at for these bushings? Thanks mang
Old Dec 27, 2003 | 10:17 PM
cb9sir's Avatar
squeakers!
Old Dec 28, 2003 | 09:13 AM
2000Accord5sp's Avatar
It all depends on how fast you can take the parts apart and put them together. But most importantly, if you don't have a press, don't try wasting your time taking the old bushings out yourself. Most of the bushings have a metal outer ring that is pressed into the arm and without the proper tools, you'll be spending hours trying to get out each bushing.
Rather take out all the parts that you'll be chaning the bushings out of, take them to a shop that has a press and have them press the old ones out. Then take them back home and put the new bushings in. Shouldn't take more than a day if you work at it and don't run into any problems like worn/torn ball joints...etc.
Also make sure to read the directions, it's important to measure some of the ball joints before removing them so you can put the new ones in exactly.
Old Dec 28, 2003 | 12:06 PM
jwogen1's Avatar
Default Re: Polyurethane Bushings Question (2000Accord5sp)
how much are you asking for the 94 EX 5 spd tranny/clutch?
StyleTEG
Nov 20, 2009 03:42 PM
wickedEFguy
20
Nov 10, 2009 04:04 PM
Overkll
12
May 19, 2003 05:11 PM
2000Accord5sp
Nov 5, 2002 11:00 AM
charjacq
May 29, 2002 12:37 PM
