won't start
Simple test. Check the ECU for a CODE 4. We had fuel and a fresh MAIN relay. It is possible that one of the sensors in the distributor has failed. If you get a CODE 4 that is the Crank ANgle Sensor. This part fails due to the bearing failing in older distributors. If you have replaced the Cap and Rotor recently and the setscrew is tight then those can be ruled out usually. With the cap off-check for red dust on the internal components--there should be none. Just my experiences.
nousername
13
Jun 17, 2003 10:28 PM
