Anyone running Toda A with stock internals?
Old Dec 27, 2003 | 11:17 AM
JDM TypeR 307's Avatar
Default Anyone running just TOda A with Stock Internals??
Dyno?? How does it feel after just putting htose cams in? I heard they are like the CTR Cams?? Experiences? Let me know! thanks
Old Dec 27, 2003 | 11:19 AM
sgT's Avatar
sgT
Default Re: Anyone running just TOda A with Stock Internals?? (JDM TypeR 508)
much more midrange and little bit top end.
better than ctr cams
Old Dec 27, 2003 | 11:23 AM
Default Re: Anyone running just TOda A with Stock Internals?? (sgT)
Is it worth it paying all that money? Or is it better buyin Toda B;s, but then you have to get valve springs and retainers rite?? Toda B's are a lot more powerful am I correct? Someone told me the Toda A's cams can produce 230whp... i dont know bout that one?
Old Dec 27, 2003 | 11:24 AM
jonas's Avatar
230whp with TODA A's? wow.. never seen that before. and especially not on stock internals
thats even hard with TODA B's
btw: i thought you sold TODA parts, shouldn't you know the answer to these more than most of us
Old Dec 27, 2003 | 11:26 AM
sgT's Avatar
sgT
if your compression is lower than 12:1 then toda A is good.
if its 12 or over then jun3 or toda c are better bets.
230whp on toda a? i doubt it.
I built a mild 11.5:1 motor that made much more midrange power with toda A
than with JUN type3, but type 3 made more peak from 7500-8500.
Old Dec 27, 2003 | 11:27 AM
do u have any dyno runs?
Old Dec 27, 2003 | 11:29 AM
jonas's Avatar
http://www.sgt-racing.com/b18c.html
Old Dec 27, 2003 | 11:31 AM
Default Re: (jonas)
how jonas how do u know so much
Old Dec 27, 2003 | 11:33 AM
Default Re: (JDM TypeR 508)
they dont have any dyno runs as Toda A
Old Dec 27, 2003 | 11:35 AM
So the verdict should be Toda A's or Toda B's?
Old Dec 27, 2003 | 11:42 AM
jonas's Avatar
the verdict depends on how much do you want to spend, and whats your goal for power.
i dont know that much, i read a lot
sgT knows a lot more from experience
Old Dec 27, 2003 | 11:46 AM
sgT's Avatar
sgT
Default Re: (jonas)
I made up the jun3 vs toda A graph, but i forgot i dont have ftp access at the
moment so i cant upload it.
my opinion, i would NEVER buy toda B cams.
Old Dec 27, 2003 | 11:49 AM
Default Re: (sgT)
why would u not buy toda b's?
Old Dec 27, 2003 | 11:53 AM
jonas's Avatar
my guess is that you might as well go with C's (if you were wanting to buy B's) since they both need almost the same amount of mods to make the most power from each
Old Dec 27, 2003 | 12:22 PM
Default Re: (jonas)
arggh... dont know wut to do
Old Dec 27, 2003 | 12:23 PM
Toda C's are they streetable.. meaning easy and normal to drive?
Old Dec 27, 2003 | 12:24 PM
sgT's Avatar
sgT
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDM TypeR 508 &raquo;</TD></TR><TR><TD CLASS="quote">Toda C's are they streetable.. meaning easy and normal to drive?</TD></TR></TABLE>
For some, not for others.
Old Dec 27, 2003 | 12:27 PM
Champ R's Avatar
Default Re: (jonas)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jonas &raquo;</TD></TR><TR><TD CLASS="quote">http://www.sgt-racing.com/b18c.html</TD></TR></TABLE>
Great dyno graphs! I need to venture down for some tuning myself come spring.
Old Dec 27, 2003 | 08:04 PM
Default Re: (Champ R)
any more opinions?
Old Dec 28, 2003 | 01:41 AM
Black R's Avatar
25 Year Member
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sgT &raquo;</TD></TR><TR><TD CLASS="quote">much more midrange and little bit top end.
.....what he said!
Old Dec 28, 2003 | 02:02 AM
Default Re: Anyone running just TOda A with Stock Internals?? (Black R)
i know you have them black R... and i guess you enjoy having the mild cams?
Old Dec 28, 2003 | 12:56 PM
Black R's Avatar
25 Year Member
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDM TypeR 508 &raquo;</TD></TR><TR><TD CLASS="quote">i know you have them black R... and i guess you enjoy having the mild cams?</TD></TR></TABLE>
I enjoy having cams allmotor. I've have spec b's in one itr, and spec a's in another. I also have spec c's that will replace the aforementioned spec b's in that motor. The spec a's will actually get b00sted on in '04!
But honestly, they're great. No reliability or idle issues. No worry about upgrading the valvetrain/ tbelt, etc. And they can make 200whp with ctr pistons. Totally reliable. Daily driver cam, imho.
Old Dec 28, 2003 | 06:17 PM
cmdr430's Avatar
i really enjoyed the spec b's. lots of low end grunt. i ran them for 20k plus miles on stock valve train and timing belt without a problem. stock rev limiter. if you plan on reving past 8500 upgrade the springs and retainers.
Old Dec 28, 2003 | 08:39 PM
QuanKwan's Avatar
I rev at 9200 RPM on stock valve train with no problems, with stock cams, if I put the toda b's will they run fine at that high of rpm?
Old Dec 28, 2003 | 08:44 PM
B2FiNiTY's Avatar
Default Re: (QuanKwan)
That would not be very safe.
