Will MSD DIS-2 fire an HVC-2 coil?
Old Dec 27, 2003 | 09:59 AM
Jared's Avatar
Default Will MSD DIS-2 fire an HVC-2 coil?
And if so will it have any problems? I've found two versions of the HVC-2, one for 7 series ignitions and one for 6 series ignitions, which one would the DIS-2 fit into?
thanks,
Jared
Old Dec 27, 2003 | 04:15 PM
tony1's Avatar
Default Re: Will MSD DIS-2 fire an HVC-2 coil? (Jared)
Bergenholtz runs a DIS4 with 4 HVC2 coils so there shouldn't be a problem.
Old Dec 27, 2003 | 08:25 PM
Jared's Avatar
Default Re: Will MSD DIS-2 fire an HVC-2 coil? (tony1)
do you know if he runs the hvc2 meant for the 7 series or 6 series ignition? they have different part numbers.
Old Dec 27, 2003 | 09:58 PM
saso
Guest
Posts: n/a
I use the dis 2 with dual coils.
Old Dec 28, 2003 | 07:15 AM
tony1's Avatar
Hmm, not sure on that. Send Ron/Ed an IM and ask them.
Old Dec 28, 2003 | 07:47 AM
Jared's Avatar
Default Re: Will MSD DIS-2 fire an HVC-2 coil? (saso)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by saso &raquo;</TD></TR><TR><TD CLASS="quote">I use the dis 2 with dual coils.</TD></TR></TABLE>
Any pics?
Old Dec 28, 2003 | 11:35 PM
James L.'s Avatar
MSD DIS-2 can fire either one safely. If you have the regular DIS-2 box, I think is better to go with the HVC-2 coil for the 6 series, or if you have the DIS-2 high output box, going with the HVC-2 coil for the 7 series would probably be better, because a DIS-2 high output box has a higher max energy Output.
Old Dec 31, 2003 | 04:57 PM
Jared's Avatar
Default Re: Will MSD DIS-2 fire an HVC-2 coil? (James L.)
Thanks for the info. What about firing two HVCs per channel of the DIS-2. Would that make a difference in coil or box life?
Old Dec 31, 2003 | 08:05 PM
saso
Guest
Posts: n/a
I use the dis 2 with dual m&w coils. The coils are internally hooked up where 1 input supplies 2 coils. I use this for my 600whp application. If you need more help call Prentice at 868 678 4687 est time. He is my tuner.
Old Jan 1, 2004 | 02:50 AM
James L.'s Avatar
HVC 2 coil for the 7 series puts out a peak current of 2 amp, and the 6 series puts out 450 ma. The regular DIS 2 box handles 4 amp at 10000 RPM, and the high output DIS 2 handles 5.3 amp at the same RPM. I don't see a problem running 2 of the HVC 2 {either} into one channel output.
JdMtR
Jan 12, 2010 11:31 AM
Hybrid
Oct 22, 2002 02:13 PM
