Is there a better ecu i can put in my stock 90 si civic
Old Dec 26, 2003 | 11:28 PM
Wes90civic's Avatar
Default Is there a better ecu i can put in my stock 90 si civic
So is ther a better ecu to use in my stock 90 si civic? Is a zc ecu better? or should i just stick with my si ecu and chip it? just wondering kinda new to this stuff, trying to learn.
Old Dec 26, 2003 | 11:47 PM
BIG RICH's Avatar
Default Re: Is there a better ecu i can put in my stock 90 si civic (Wes90civic)
if you can find an 88-89 integra ECU, that would give you a little more. my friend has ran one in his 90 CRX Si, and has had no problems. pulls alot harder then stock. really.
Old Dec 26, 2003 | 11:50 PM
Wes90civic's Avatar
Default Re: Is there a better ecu i can put in my stock 90 si civic (BIG RICH)
So im going to be dumb for a sec, like i said im new to this, so if i find a 89-90 integra ecu, what do i have to do just unplug mine and plug it in, or are the certain steps i have to take?
Old Dec 26, 2003 | 11:52 PM
Tw1n Turb0 Z's Avatar
Does this specifically need to be 88-89?
A 90 will not work? (ecu from teggy)
Old Dec 26, 2003 | 11:56 PM
Wes90civic's Avatar
Default Re: (Tw1n Turb0 Z)
Im not sure other guy just said his friend uses a 89-90 and it pulls a little harder
Old Dec 27, 2003 | 12:00 AM
BIG RICH's Avatar
yes you just unplug yours and plug the new one in. you may want to disconnect the battery, for safety reasons. the 88-89 would be the best, because the 90-91 has more agressive fuel tuning. it probably wouldn't be as good for normal driving. I would think that atleast.
Old Dec 27, 2003 | 12:04 AM
Wes90civic's Avatar
Default Re: (BIG RICH)
Thanks for info big rich, i was pretty sure you just plug it in but i was just making sure
Old Dec 27, 2003 | 12:08 AM
Ash J. Williams's Avatar
Good, Bad…I'm the one with the gun
From: Trapped in time, Surrounded by evil, Low on gas
Default Re: (Wes90civic)
i'm running Pm7 maps on my PM6, timing is advanced somewhat as well.
follow the white rabbit and read on...http://pgmfi.org
don't for get to donate...
simply putting a teg ECU on your D16 is not such a good idea
stan
Old Dec 27, 2003 | 12:13 AM
BIG RICH's Avatar
Default Re: (90crxsi)
why not exactly? my friends has been working great for a while. he's had it in for 6-8 months with no problem. it may run a little rich just cruising but it's great for fun driving. what problems could happen?
Old Dec 27, 2003 | 12:40 AM
precisely that, it runs rich. a better solution would be taking the maps of the teg ECU and tuning them for the right engine.
Stan
Old Dec 27, 2003 | 01:42 AM
Fobtions's Avatar
since you have a pm6 that is chippable, try out a aftermarket rom. you can use pr4 roms also.
Old Dec 27, 2003 | 01:45 AM
SiR Kid's Avatar
New User
Default Re: (Fobtions)
Make SURE it's an 88-89. 90 is the B18a which will KILL the little d16a6 engine with fuel.
88-89 is a 1.6L DOHC engine rated at 112 HP, so it's VERY similar to the stock engine in the 88-91 Civic, only slightly better because of head design.
Hope this helps.
Old Dec 27, 2003 | 07:38 AM
blah13's Avatar
Default Re: (SiR Kid)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SiR Kid &raquo;</TD></TR><TR><TD CLASS="quote">Make SURE it's an 88-89. 90 is the B18a which will KILL the little d16a6 engine with fuel.
Hope this helps.</TD></TR></TABLE>
Right on, dont get a 90 or above.
Old Dec 27, 2003 | 08:16 AM
Kutsuju_SLeePER is gay
Guest
Posts: n/a
Default Re: (blah13)
are all these posts confusing you lol
88-89 only
90-91 out of question
for the risk of such a lil mod then you should pass it up NO?
cuse if you blow up your lil motor that could
its not our fault
Old Dec 28, 2003 | 04:24 PM
Fobtions's Avatar
Default Re: (2001-ITR#420)
if you do have a 90-91 you have the option of chipping it to whatever spec u want. So its not bad at all.
Old Dec 28, 2003 | 04:29 PM
onePOINTsix's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 90crxsi &raquo;</TD></TR><TR><TD CLASS="quote">follow the white rabbit and read on...http://pgmfi.org</TD></TR></TABLE>gotta love pgmfi project!!! please dont be a leech
oh and BTW i have a PG7 from a 89 Teg for sale... PM me
Old Dec 30, 2003 | 09:43 PM
lemonhead's Avatar
I'm using a PR4 from an b18a obd0 integra ls in my ef with a zc no modification better mapping equal to a b series but you will probably need a fuel pressure regulator cause sometimes it can run rich just a thought
socialistic
Oct 31, 2010 02:29 PM
RiceBoysDream
Nov 13, 2003 01:18 PM
Kasper.
14
Aug 10, 2002 06:27 PM
