How is this?
I'm planning on getting a 92-95 Civic HB and getting a GSR swap from hmotorsonline.com.
I was wondering around how much power this would make..
Skunk2 Stage 2 Camshafts
Skunk 2 Intake Manifold
Skunk 2 Cam Gears
Comptech header
Comptech Ice box intake
comptech exhaust
RC Engineering 440cc Injectors
Hondata
I'm not sure which pistons I would use Arias makes 14:1 pistons is it even possible to run 14:1 on pump gas? 93 octane
If not what is highest that I can run without risking damage to engine?
thanks.
Skunk 2 Cam Gears
Comptech header
comptech exhaust
Hondata
thanks.
Tough to get 14:1 on a stock bore/stroke, even with the biggest dome you can find. And if you are going over 12:1, you might a well go with Skunk 3's. Depending on how well built/tuned the motor is you are looking at between 190-220 whp.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Miz101 »</TD></TR><TR><TD CLASS="quote">I'm sorry the Arias pistons are 13.6:1 and specs on them are bore: 3.346 stroke: 3.433</TD></TR></TABLE>
That is not a stock bore. 3.346 X 25.4 = 84.9884 mm. (85mm)
Stroke is stock GSR/ITR-3.433 X 25.4 = 87.1982mm. (87.2mm)
My original point was that it's difficult to get the compression up that high with a stock bore. If you sleeve the motor and go 85mm, you can definitely get the compression up there. I am running an 85mm GSR engine in my Civic right now as a matter of fact, and compression is in the neighborhood of 14:1. I can vouch for this setup
You can't bore a stock block to 85mm BTW.
Guest
Posts: n/a
Pump gas on 14:1 comp. Even if you got it to run without detonation u would have to run the motor so rich it would defeat the purpose and lose power. If you want to drive the car alot. Buy a 55 gallon drum of vp or about 4 headgaskets. But thats just me
Alright thanks.
How about valve springs, retainers and valves? Should I use Skunk 2 for them as well?
And should I still go with Stage 3's ? How would the idle be with them?
Skunk 3's idle like stock. Personally, I like Toda valve springs and stock ITR valves. Any good Titanium retainer is fine-Skunk, Portflow, etc.
BRIANxJDM
Honda Civic (2006 - 2015)
16
Jun 23, 2009 09:24 PM
iDeNtiTy
16
Jan 3, 2007 06:28 AM
