ls/vtec help
i got a ls/vtec set up 95 ls block stock and a 97 gsr head. Oil lines and everything is run. The vtec activates but the car is slow as fvck! I'm running it in a 95 ls integra and i can't even beat my frens in stock 90 ls integras. The vtec activates but the car doesn't move it's just a noise machine. The vtec hits, the car screams, but doesn't really move anywhere. Any ideas what could be the problem.
Oh i'm also running a p72, headers, cold air intake, full piping, and a ACT clutch in my stock ls tranny.
Any ideas to fix this i know it's not supposed to be like this.
can't really expect too much with a stock block... you needed to put at least some ITR pistons, some Cams would really help out and the LS tranny is also killing you
yes do away with the ls tranny it suks w/vtec a good strong lsvtec motor would be w/a b16 trany or gsr, i recomend b16 trans http://cgi.ebay.com/ebaymotors...14888 check out my ebay
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Drag_Racer_DRU »</TD></TR><TR><TD CLASS="quote">can't really expect too much with a stock block... you needed to put at least some ITR pistons, some Cams would really help out and the LS tranny is also killing you</TD></TR></TABLE>what he said^
what u have basically is a stock motor still (even w/ that vtec head); up the compression and a pair of bigger cams and you'll really be moving
Check out the power differences in these ls/v set ups.....
the first one is with stock everything....
and heres a mildy modded set up........
Now every motor is different, but this set up gained almost 50hp just from cams, pistons, a header, tuning, and hondata. Not bad at all IMO.
thanks for all the replys guys but shouldn't my motor atleast be faster than a stock LS because i just raced my fren with the same kind of car but with a stock LS and his is faster, alot faster.
I definitely see what you are saying but what year LS is his it might have different gearing. You could try advancing your timing a little. I had a problem a while back with my ls/vtec when vtec kicked in there was no power but it sounded like it was kicking in. It turned out that my b&m fpr was faulty. If you have an after market one try swapping it with a stock one. My 2 cents.
this sounds kinda like what i'm experiencing. Vtec kicks in but the car lags. maybe i'll switch fpr with my fren to test it i'm running a stock one right now.
I raced a 95 LS integra both of us driving in second gear on the freeway, stomped the gas and i straight up got murdered. stock LS vs LS/vtec with mods, LS wins thats not right.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by granada_sun »</TD></TR><TR><TD CLASS="quote">Check out the power differences in these ls/v set ups.....
Now every motor is different, but this set up gained almost 50hp just from cams, pistons, a header, tuning, and hondata. Not bad at all IMO. </TD></TR></TABLE>The thing about these dyno graphs is that they really don't list all of their mods.....If people can really just throw on some pistons, a header, and hondata, and some mild cams, and really tune an extra 50hp it would be amazing
Colorado_teggy
May 23, 2015 10:50 AM
