B18C1 Head Q's.. Dowel Pin Placement + headgasket... urgent help!!
Old Dec 26, 2003 | 09:21 PM
navin's Avatar
Default B18C1 Head Q's.. Dowel Pin Placement + headgasket... urgent help!!
hey guys, got the urge to put my motor back together. I think I am having a brain fart tonight, so I thought Id ask for help..
anyways - where are the dowel pins for the head supposed to be located, exhaust or intake side..? And are supposed to sit inside the holes flush or not?
Headgasket - Is there any special direction to have it on. I have it facing right side up [says "UP" on intake side] is this correct??
please help!! im we-todd-did!
Old Dec 26, 2003 | 09:38 PM
b19coupe's Avatar
Default Re: B18C1 Head Q's.. Dowel Pin Placement + headgasket... urgent help!! (navin)
Dowel pins do not sit flush. The whole purpose of the dowel pins is to line up the head, block, and head gasket. The head gasket goes in with the "up" up obviously, and the silver tab that says "P30" on the transmission side of the engine, towards the front. The head gasket will also tell you where the dowel pins go, only two holes in the gasket big enough for them.
Old Dec 26, 2003 | 09:58 PM
navin's Avatar
Default Re: B18C1 Head Q's.. Dowel Pin Placement + headgasket... urgent help!! (b19coupe)
yah i just figured it out while I was in the garage... my stupidity
simpletuning
Classic Hondas
11
Oct 8, 2009 03:53 PM
headpot420
Dec 27, 2008 12:52 AM
john457
Mar 17, 2007 02:11 PM
urtz
Dec 14, 2006 09:33 PM
