Mhow do i remove the rear emblems
Old Dec 26, 2003 | 09:20 PM
VTECdTypS's Avatar
Default Mhow do i remove the rear emblems
i wanna remove the 'ACURA' AND 'RSX-S' emblems but how do i do it so there
isnt ne glue or whatever holds it on there
Old Dec 26, 2003 | 09:23 PM
dacaveman's Avatar
What I did to remove my emblems was take fishing wire and put it behind the emblem and move in a left right motion and it took off the embelm but left alot of glue. What I have seen other people do is take a flat head screwdriver put a towel or rag over it and take it off that way. It still leaves the glue though. That is a real bitch to take off. But I know that 3m makes some stuff that takes that glue off in a jiffy. I wasn't lucky enough to have it though. But you can go to your local store and buy it. Hope this helps.
Old Dec 27, 2003 | 06:41 AM
crxagogo's Avatar
Default Re: Mhow do i remove the rear emblems (VTECdTypS)
...Goo- Gone and fishing line or dental floss will do the trick. Soak the glue down behind the emblem with the goo- gone (it's paint safe) and let it soften the glue up for maybe 5 or 10 minutes. After it's been softend up some use the dental floss/fishing line like a saw, moving back and forth/ up and down or whatever. The glue that's left resoak it with the goo gone and wait a coulple minutes and use some elbow grease and more goo-gone to get it all off. Wash and wax the area when finished....
Old Dec 27, 2003 | 07:48 AM
flying's Avatar
What makes it really easy is do it when the car has sat in the sun for a few hours. Or if not then use a blow dryer to get it hot. Then use dental floss or just pry it with your fingers. Then again with the blow dryer heat the remaining goo & you can just ball it up with your fingers by rubbing.
slow-dc5
22
Apr 11, 2007 04:55 PM
UA6 BALLER STATUS
Nov 30, 2004 12:08 AM
aesthetics82
34
May 10, 2004 07:52 PM
2000CX
Jun 25, 2003 09:43 AM
itr501
Jun 23, 2001 05:33 PM
