Benefit of an Upper rear tie bar?
Old Sep 24, 2001 | 01:18 PM
R-Adrenaline's Avatar
New User
Default Benefit of an Upper rear tie bar?
What kind of benefits will I notice with an upper rear tie bar. I just ordered a Neuspeed and wanted to hear some peoples opinions, experience, noticable improvements or not??
[Modified by R-Adrenaline, 10:18 PM 9/24/2001]
Old Sep 24, 2001 | 01:29 PM
Cosworth's Avatar
Default Re: Benefit of an Upper rear tie bar? (R-Adrenaline)
Barely any noticeable gain on the streets. I'm not so sure if you'd feel that much it even at the limits. You should've picked up a 26mm sway bar instead.
Old Sep 24, 2001 | 01:30 PM
GRM Scott's Avatar
25 Year Member
Autocrossing, the rear felt ever so slightly more tossable with the rear bar in place. Ultimately, it can't hurt long-term to increase chassis rigidity and reduce flex etc, but it's not the night and day difference that a real rear swaybar is to a GS-R, for example. A 26mm rear bar would be a more dramatic change, but i'm glad i got my JDM RSTB.
Old Sep 24, 2001 | 01:37 PM
The Kernel's Avatar
The ITR already has a trunk brace and lower tie bar but if you don't need the trunk space why not?
I think F&R Mugen 26mm sway bars would really reduce body roll but they're $$$.
Old Sep 24, 2001 | 01:48 PM
PiYoImuT's Avatar
Default Re: Benefit of an Upper rear tie bar? (NBP #0933)
What's the size of the stock sway bar??
Old Sep 24, 2001 | 01:52 PM
Cosworth's Avatar
Default Re: Benefit of an Upper rear tie bar? (PiYoImuT)
USDM has 23mm, I think.
Old Sep 24, 2001 | 01:53 PM
GRM Scott's Avatar
25 Year Member
Default Re: Benefit of an Upper rear tie bar? (Cosworth)
Pretty sure USDM is 22 rear, 24 front. JDM is 23...?
Old Sep 24, 2001 | 02:48 PM
Mike M's Avatar
Founding Member
Default Re: Benefit of an Upper rear tie bar? (Aleph)
US is 22 rear 24 Front
JDM is 23 Rear 24 Front and also better Upper Control Arms
Old Sep 24, 2001 | 03:11 PM
Tommy_Gunns's Avatar
Default Re: Benefit of an Upper rear tie bar? (TypeRmsm)
Yeah, how come Honda gives us that crap stamped steel upper control arms. JDM ones are much more solid...but I wonder if you'd feel the difference for SoloII.
Old Sep 24, 2001 | 03:13 PM
Mike M's Avatar
Founding Member
Default Re: Benefit of an Upper rear tie bar? (Tommy_Gunns)
I could just using them on the street
Cody08
May 1, 2018 09:28 AM
Try2Live4God
Feb 23, 2005 06:30 AM
slocrxsi
Sep 5, 2003 02:03 PM
VTEC-DA
Oct 18, 2002 05:54 AM
