cannot Locate IGNITION TIMING ADJUTING CONNECTOR
as indicated in figure 1 bellow :
http://www.binghamtonlife.com/...8.jpg
please help, aol is glockdub2
many thanks!
many thanks!
Check under the hood on the driver's side. It should be sticking out of the harness in front of the midway between the shock tower and the headlight.
On my '90 CRX DX and my '90 CRX Si they're both under the glovebox right next to the pass. kick panel and blower motor.
thanks Found IT! its acutaly under the dash near the ECU on the 91
Now if I could only set the timing
its way off, and I already checked the CAM timing just to be sure
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by USDM91crxSi »</TD></TR><TR><TD CLASS="quote">thanks Found IT! its acutaly under the dash near the ECU on the 91</TD></TR></TABLE>
Oh ok you have a 91, I would've never guess by your name
to me. Most 88-89 models have them under the hood.
You can tell by the illustartion, it shows the blower motor
</TD></TR></TABLE>You can tell by the illustartion, it shows the blower motor
flanker
10
May 23, 2008 09:02 PM
