If i put my a6 into my std hatch will this fit?
Old Dec 26, 2003 | 03:37 PM
Red_Si's Avatar
Default If i put my a6 into my std hatch will this fit?
i need to know if the hose diameters for the radiators are the same??? will my std radiator work with the a6 swap??? please let me know
Old Dec 26, 2003 | 03:56 PM
Riceburner247's Avatar
Default Re: If i put my a6 into my std hatch will this fit? (Red_Si)
If they're not the same, then just snag a si radiator.
Old Dec 26, 2003 | 04:08 PM
4crx4me's Avatar
Default Re: If i put my a6 into my std hatch will this fit? (riceburner247)
I'm 99% sure ALL 88-91 civic/crx radiators are interchangeable. They're ALL the same.
Old Dec 26, 2003 | 05:59 PM
JonGP4's Avatar
Default Re: If i put my a6 into my std hatch will this fit? (4crx4me)
they are all the same but they will all work with each other.. you can do just about any setup it will work
Old Dec 26, 2003 | 06:17 PM
plonger's Avatar
Default Re: If i put my a6 into my std hatch will this fit? (JonGP4)
Yes it will work .
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JonGP4 &raquo;</TD></TR><TR><TD CLASS="quote">they are all the same but they will all work with each other.. you can do just about any setup it will work</TD></TR></TABLE>
the std radiator is not the same as other . He is small
On the first link you see a si/dx radiator and on the second pic its a std rad
http://user.icx.net/~drizzt/enginebay2.JPG
http://home.1asphost.com/plonger/moteur.JPG
4crx4me's Avatar
They will ALL interchange with any model or year of car.
The only difference I've found is sometimes the fan(s) mounts to one differently than another by manufacturer.
Denso=Denso
Toyo=Toyo
They'll all fit the car but maybe NOT the fan(s).
Old Dec 26, 2003 | 06:25 PM
VTECVillain's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Red_Si &raquo;</TD></TR><TR><TD CLASS="quote">i need to know if the hose diameters for the radiators are the same???</TD></TR></TABLE>
Yes they use the same hoses.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote &raquo;</TD></TR><TR><TD CLASS="quote">will my std radiator work with the a6 swap???</TD></TR></TABLE>
Yes it will work no problem. The STD radiator is about 2-3" less in width than the DX/Si radiators. It also has a different upper mount bracket on the driver's side that bolts in a few inches closer to the center on the radiator support.
Old Dec 27, 2003 | 05:36 AM
Red_Si's Avatar
Default Re: If i put my a6 into my std hatch will this fit? (VTECVillain)
thanks alot guys, you saved me some money
gtarwiz
Jun 2, 2005 01:06 PM
acurar0ss
Jan 1, 2005 08:16 PM
doublethink
Oct 15, 2004 09:56 PM
r0c5t4r
Jun 28, 2004 10:18 AM
litterbox
May 22, 2004 02:07 AM
