What car to get a cap, rotor, plugs and wires from for b16a1?
Old Dec 26, 2003 | 03:07 PM
luckybull's Avatar
Default What car to get a cap, rotor, plugs and wires from for b16a1?
what motor should i take the parts i need from?
Old Dec 26, 2003 | 03:13 PM
RCautoworks's Avatar
Default Re: What car to get a cap, rotor, plugs and wires from for b16a1? (luckybull)
Water Pump 19200-P30-003 94 - del sol
Head Gasket 12251-P30-014 94 - del sol
Oil Control Orfice O ring 15142-PH3-003 94 - del sol
Intake Manifold Gasket 17105-P30-004 94 - del sol
Exhaust Manifold Gasket 18115-P30-013 94 - del sol
throttle Body Gasket 16176-PR3-010 90-91 integra
Pcv valve 17130-PM6-G01 94 - del sol
Timing Belt 14400-PR3-004 94 - del sol
Alternator Belt 31110-PR3-003 94 - del sol
Tensioner 14510-P30-003 94 - del sol
Thermostat 19301-P08-305 90-91 integra / 94 del sol (same)
Connecting Pipe O rings (2) 91314-PH7-003 90-91 integra / 94 del sol (same)
Cap & Rotor Assembly 06303-PR4-000 90-91 integra
Rotor (If needed seperately) 30103-PR3-016 90-91 integra
Clutch Cable 22910-SK7-A02 90-91 integra
Throttle Cable 17910-SK7-A03 90-91 integra
Cam Seals (2) 91213-PR3-004 94 - del sol
Oil pan seal 11251-P30-004 94 - del sol
Oil Pump (comes with crank seal) 15100-PR3-024 94 - del sol
Oil Filter 15400-POH-305 94 - del sol
Oil Pick Up Gasket 15221-PW0-S01 94 - del sol
***** Pin Shift Linkage 91 crx si ???
Shift linkage bushing 54303-SB2-010 90-91 integra
crank seal 91212-PR3-003 94 - del sol
rear main seal 91214-PH1-004 90-91 integra / 94 del sol (same)
Valve cover grommets -8- 90442-P30-000 94 - del sol
Spark Plug O rings (4) 12342-P66-000 94 - del sol
Rubber plug for exhaust cam tranny side 94 - del sol
Spark Plugs (4) BKR6E-N11 NGK
Spark Plug Wires 32722-PR4-A01 92 - integra gsr
Upper Radiator Hose 19501-PR3-000 92 - integra gsr
Lower Radiator Hose 19502-PR4-A00 90-91 integra
Bypass Hose (Thermostat) 19508-P08-000 94 - del sol
Washer for coolant drain on block 90401-PR4-000 94 - del sol
Old Dec 26, 2003 | 03:16 PM
Rob!'s Avatar
Default Re: What car to get a cap, rotor, plugs and wires from for b16a1? (90blackcrx)
thats good info...woulda been helpful during my swap 2 years ago...
kim_2_da_chee
Mar 10, 2004 01:12 PM
coot_er
Mar 4, 2004 04:58 PM
conceptEG
Sep 4, 2003 10:44 AM
91hatchnewb
Apr 28, 2003 01:54 PM
bluecrxsi
22
Feb 25, 2003 04:47 PM
