got a noise, can't figure it out
Old Dec 26, 2003 | 06:13 AM
defaced's Avatar
Default got a noise, can't figure it out
Ok, I have a 94 Accord Ex. If my car is sitting in park or neutral and I rev it to about 2300 there's like a clicking noise coming from the engine. Anything below or above 2300 there's no noise. It does the same thing when I'm driving too. It's not just when I'm sitting still. I had my friend listen to it and he couldn't figure out what it was coming from. I was in an accident last year and when they fixed everything I kinda had the same problem and I took it to the dealer and I guess there was somthing loose. Could that have possibly gotten knocked loose again? I'm not sure what it was though. If any of you have ever had this problem, what was it? Or if you know what the problem is please tell me. I'd like to get this fixed. Thanx in advance.
Old Dec 26, 2003 | 07:16 AM
The_Todd's Avatar
Farts in the shower
Default Re: got a noise, can't figure it out (defaced)
you might need a valve adjustment......when my car is cold at certain rpms it will make a click...is it coming from the valve cover?, if so your rockers and valve springs are making that clicking......need to get it fixed
Old Dec 26, 2003 | 11:40 AM
SOHCMAN's Avatar
Default Re: got a noise, can't figure it out (VRDrvr)
Ya, so I just had my valves adjusted because like you, my valves click between 2K and 3K, best heard when accelerating. and they still do it, maybe worse now since the adjustment.
Is this somehting to simply expect from an engine with almost 130K on it??
thanks, sohc
Old Dec 26, 2003 | 02:11 PM
The_Todd's Avatar
Farts in the shower
Default Re: got a noise, can't figure it out (SOHCMAN)
The rockers against the pushrod and the springs are what usually rattle, sometimes even after readjusting it will still make a slight noise, mine does but only when its cold, you may want to replace the springs, pushrods etc, just due to old parts and if your doing that you might as well pull the engine and or swap it just my 2 pennies.
edit: this pic courtesy of howstuff works
Modified by VRDrvr at 4:38 PM 12/26/2003
Old Dec 26, 2003 | 02:36 PM
carolinaACCORD's Avatar
automatic or manual?
if it's automatic, it could be the rear mount control solenoid trying to switch over and can't. long shot though, because those usually don't mess up, unless they're messed up in a wreck.
more than likely you just need a valve adjustment.
Old Dec 27, 2003 | 07:10 PM
defaced's Avatar
Default Re: got a noise, can't figure it out (carolinaACCORD)
it happens when it's trying to shift, and yes it is an automatic, and yes I was in a wreck. Does that help any?
Old Dec 27, 2003 | 10:19 PM
Razor's Avatar
maybe something simple as a loose heat shield
Old Dec 28, 2003 | 08:54 AM
stinker504's Avatar
I have a simular sound too, but it's different. It comes only after a long drive and I can only hear it in neutral between 2-3 grand. Any idea guys?
Old Dec 28, 2003 | 09:52 PM
SOHCMAN's Avatar
Default Re: (stinker504)
Its got to be plain and simple valve trian wear... THat is, if it doesnt go away after a valve adjustment. The question is, replace the racks? or just drive with it? any big risks to waiting until somehitng breaks?
Old Dec 30, 2003 | 05:58 PM
DragonTLS's Avatar
check the front engine mount
Old Dec 30, 2003 | 09:56 PM
Kack's Avatar
Default Re: got a noise, can't figure it out (DragonTLS)
what should i be checking for?
Old Dec 31, 2003 | 10:23 AM
SOHCMAN's Avatar
Default Re: got a noise, can't figure it out (Kack)
wear, loosness, excess travel...
BUt how would a bad front mount cause ticking at certain rpm?
sohc
iamthefollower
Apr 23, 2012 04:07 PM
yellowbuffalo
Feb 6, 2003 03:09 PM
BryanS
Sep 25, 2001 10:46 AM
