My engine bay Cleanup. Full write-up. By popular demand!! *pics*
Old Dec 25, 2003 | 09:59 PM
NickQ's Avatar
Default My engine bay Cleanup. Full write-up. By popular demand!! *pics*
By popular demand, I have Made a list of what I did to clean-up my engine bay. Hope it helps you out.
Then <FONT SIZE="1">LS turbo</FONT>
Now <FONT SIZE="1">Swapped in a B18C</FONT>
Besides the obvious swap from LS turbo to stock GSR
Removed
<FONT SIZE="1">* AC (ALL components, wires, and lines)
* PS (ALL components, wires, and lines)
* Drag 3 turbo (and ALL components, wires, and lines) from the LS
* ITR radiator (replaced w/ stock civic radiator, and single Fal slimline fan)
* Washer fluid resivior
* Stereo circuit breaker
</FONT>
Relocated
<FONT SIZE="1">* ALL wiring from wiring harness
-Wiring moved from on top and across fender well, to underneath chassis, and outside of the engine bay. Between the fender and engine bay.
* Headlight wiring
-For both sides, I cut the headlight wiring, and ran it through a little hole in the chassis behind the headlamp assembly. Then I connected the wiring using solderless butt connectors, then heat wrapped it with black heat wrap.
* Radiator catch can
-I took off the front facia, and attached the can to the center radiator support, on the passenger side in front of the radiator, using black gardener's plastic coated wire. All that was needed after that was a hose long enough to reach it.This will not affect cooling enough to even matter. I have not seen ANY rise in tempature.
* Brake booster vaccume hose and check valve
-I bought a line of hose long enough to run underneath the booster and up to the intake manifold (approx 24"). I then used a pair of pliers to rotate the fitting on the top of the intake manifold to face down to better hide the hose. Be careful while doing this as not to break it off. I have noticed that on some engines, it is almost impossible to move without breaking.
* ALL battery wiring
-I removed the battery and all mounting hardware. I moved all wiring behind the battery and underneath the mount. I ran the negative wire behind, and around the passenger side to the fender wall. I moved the positive power wire behind and underneath the battery. Then up to the fuse block. I moved the positive starter wire behind and underneath the battery, under the chassis, and to the starter. (see Replaced section for new wire treatment)
* ALL misc. motor wiring (including; distributor, O2 sensor, VTEC, and GSR intake secondary wiring)
-Heat wrapped, and moved as close to the motor, and under the intake manifold, as possible, using black zip-ties.
* Fuel injector wiring
-While fuel rail was off (see Painted section) I disconnected the injector wiring. I removed all of the stock heat wrap from the injector wiring, pulled out as much as I could through the harness, and re-wrapped it with heat wrap. This lengthened the wiring just enough. I then ran each wire and connector as follows: I ran the wire for cylinder #1 (going from left to right) through the 1 & 2 runner. #2 through the 2 & 3 runner. #3 through the 3 & 4 runner. #4 on the outside of the #4 runner.I put back on the fuel rail, leaving the wiring underneath, and plugged the injectors back in. You will have to spin the injectors so that the connector is pointing at the driver (kinda diagonal-right). </FONT>
Replaced
<FONT SIZE="1">* ITR radiator for smaller, stock radiator
* Top radiator bracket
-I removed the stock radiator bracket. I cut a short length of metal plumbers tape and bent it to shape. This is a lot smaller and, in my opinion, looks much better. Then I attached it in place of the original.
* STR oil cap for stock oil cap
* Battery terminals (my little secret . If you really want to know what terminals I used, PM me)
-I used 0 gauge, Stinger ground wire (completley covered in heat wrap) with stinger gold connectors on everything.
* ALL ground wires
-I used 0-4 gauge stinger ground wire, completley heat wrapped in black, with stinger gold conectors.
* Red 8mm spark plug wires for stock black wires</FONT>
Painted
<FONT SIZE="1">* Engine bay
* Valve cover
(Complete Write-up: https://honda-tech.com/zerothread?id=622687 )
* Spark plug wire cover
* Fuel Rail
* Fuel pressure regulator
* Cap on the passenger side of fuel rail
* VTEC solenoid
* Battery
* Battery hold down
* Master cylinder
* Clutch resivior bracket
* Intake manifold diaphram (top left)
* ALL motor mounts
* Exaust heat shield
* Radiator
* Radiator cap
* Radiator hold down bracket
(see Replaced section)
* Hood latch (will not affect functionality)
* Tranny fluid line bracket (lower left)
* ALL brake lines
* ALL fuel lines
</FONT>
Materials used
<FONT SIZE="1">* Paint
-Duplicolor 1200 degree engine enamel (satin black)
-Duplicolor black textureized paint (valve cover)
-Any Primer</FONT>
<FONT SIZE="1">* Paint stripping
-Aircraft paint remover (spray)
-GOOD pair of anti-corrosion gloves
-Fine grit wet sanding paper</FONT>
<FONT SIZE="1">* Wiring
-0 to 4 gauge Stinger ground wire
-Stinger gold wire connectors
-Black heat wrap
-Black electrical tape
-Black zip ties</FONT>
<FONT SIZE="1">* Misc.
-Metal plumbers tape
-Any masking tape for painting
-Simple Green spray for degreasing
-Hose from any auto parts store
-I replaced all nuts and bolts that I could with new, black ones from the hardware store</FONT>
If you have any questions, feel free to PM me or email me @ NickQuisenberry@yahoo.com
Modified by NickQ at 12:19 AM 12/26/2003
Old Dec 25, 2003 | 10:08 PM
RyanAutry's Avatar
Default Re: My engine bay Cleanup. Full write-up. By popular demand!! *pics* (NickQ)
Cleanest Engine Bay Eva!
ophdehEEzY
Guest
Posts: n/a
Clean engine bay!
Seems like u painted a bunch of shiet...
Old Dec 25, 2003 | 10:24 PM
hybridzOr's Avatar
Default Re: My engine bay Cleanup. Full write-up. By popular demand!! *pics* (ophdehEEzY)
that is a very good tutorial.....but should have been done in steps
still good and clean, and stealthy
Old Dec 25, 2003 | 10:26 PM
NickQ's Avatar
Default Re: My engine bay Cleanup. Full write-up. By popular demand!! *pics* (HybridRacer)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by HybridRacer &raquo;</TD></TR><TR><TD CLASS="quote">that is a very good tutorial.....but should have been done in steps
still good and clean, and stealthy </TD></TR></TABLE>
There were really no steps involved. I just did stuff as I noticed it. Except for the engine bay. That was done during the swap.
Old Dec 25, 2003 | 10:51 PM
chaudanova's Avatar
Mucho props to you man, thats real good work...
Old Dec 25, 2003 | 11:02 PM
plusONE jboy's Avatar
Engine bay looks good man.
Old Dec 25, 2003 | 11:03 PM
hybrider's Avatar
Default Re: My engine bay Cleanup. Full write-up. By popular demand!! *pics* (chaudanova)
that puts my engine bay to shame
Old Dec 25, 2003 | 11:22 PM
DownBoyDown's Avatar
Too much time on your hands?
Old Dec 25, 2003 | 11:30 PM
NickQ's Avatar
Default Re: (DownBoyDown)
you got it.
lol
Old Dec 25, 2003 | 11:50 PM
skamal's Avatar
Default Re: (NickQ)
good writeup, this is gonna go in my fav's.
Old Dec 25, 2003 | 11:54 PM
Ekizzle's Avatar
Default Re: (skamal)
Too much black for me and not enough shine but If you like it then to you !
Good write up and thank
Old Dec 26, 2003 | 02:11 AM
GoT HaTcH's Avatar
Default Re: (AREA 51)
looks like alot of work.. good job!
Old Dec 26, 2003 | 05:34 AM
sikciv666's Avatar
DAM ME LIKEY!!, question though why no more turbo?
Old Dec 26, 2003 | 07:49 AM
RobbieG35's Avatar
12 Years Strong
Default Re: My engine bay Cleanup. Full write-up. By popular demand!! *pics* (sikciv666)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sikciv666 &raquo;</TD></TR><TR><TD CLASS="quote">DAM ME LIKEY!!, question though why no more turbo?</TD></TR></TABLE>
Thats what I was thinking??? Turbo
Old Dec 26, 2003 | 09:32 AM
RyanAutry's Avatar
His turbo kit will be put on in April.
Old Dec 26, 2003 | 09:54 AM
DrunknMunky's Avatar
Default Re: My engine bay Cleanup. Full write-up. By popular demand!! *pics* (RyanAutry)
good write up. thanks for all the info!
Old Dec 26, 2003 | 09:58 AM
NickQ's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sikciv666 &raquo;</TD></TR><TR><TD CLASS="quote">why no more turbo?</TD></TR></TABLE>
Because GSR &gt; LS and the drag 3 licked *****.
New turbo will be on around march/april
Old Dec 26, 2003 | 10:11 AM
sikciv666's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by NickQ &raquo;</TD></TR><TR><TD CLASS="quote">
New turbo will be on around march/april </TD></TR></TABLE>
holla!!!
RyanAutry's Avatar
Because, GSR &gt; LS and the drag 3 licked *****.
Old Dec 26, 2003 | 10:36 AM
JDMlyfestyle's Avatar
Used your write up bro. helped alot here are the results
Before
After
Old Dec 26, 2003 | 10:41 AM
NickQ's Avatar
Default Re: My engine bay Cleanup. Full write-up. By popular demand!! *pics* (JDMlifestyle)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDMlifestyle &raquo;</TD></TR><TR><TD CLASS="quote">Used your write up bro. helped alot here are the results[/img] </TD></TR></TABLE>
Cool! Glad I could help!!
Old Dec 26, 2003 | 11:03 AM
ophdehEEzY
Guest
Posts: n/a
Before
After
HAHAHAHAHahahHAhAH!!
Old Dec 26, 2003 | 04:08 PM
RyanAutry's Avatar
Old Dec 26, 2003 | 04:09 PM
JoshuaVTEC's Avatar
NICE!
I personally like all my creature comforts BUT it's a nice motor, I'll give you that...
