Camber kit for NSX?
To adjust for more negative or less?
If more negative, Comptech has these: http://solar.innercite.com/comptech/160030.html
"These mounts make it possible subtract up to 2 degrees camber, allowing for alignment to be brought into the -4 degree range desired by track driven NSX's with slicks.
These machined ball joint mounts will press into the upper and lower control arm and offset the main upright, giving you more static negitive camber to start with, then adjust the alignment as normal to your specific track specifications.
Once in place these mounts are fixed & can not be adjusted.
Kit comes with parts for both front upper and lower control arms of the Acura NSX.
fits: 1991-2003 Acura NSX."
If less negative, you'll be able to tune with the stock adjustment. Is the car lowered?
6doorsentra
19
Jul 10, 2007 11:11 AM
russianswty
Mar 9, 2007 10:26 PM
