jerky cruising
Old Dec 25, 2003 | 08:38 PM
stRodda's Avatar
Default jerky cruising
for the past couple days now, ive noticed it really come on. one instance in which i was coasting in 2nd through a parkinglot... my car would almost lunge foward by itself as if i was tapping the gas.
and again today, i noticed it on the freeway. not really when accelerating, but just when cruising. i was in 5th going around 70-80 and i would feel a slight jerk, back and forth. and it wasnt constant. it would happen at random intervals.
what are some possible problems... or THE problem?
Old Dec 25, 2003 | 08:43 PM
persianprelude's Avatar
try cleaning your throttle body with some t-body cleaner. Sounds like you may have a sticky t-body or use some fuel injector cleaner. Good luck
Old Dec 25, 2003 | 08:47 PM
stRodda's Avatar
Default Re: (persianprelude)
k, thanks. ill try that cleaner thing. im probably getting retuned in a couple days, so ill know if its a fuel problem.
is this a normal problem? are there any other common remedies?
Old Dec 25, 2003 | 09:49 PM
bad-monkey's Avatar
on another note, my cruise control has been pretty jerky lately making for some unsmooth "cruising"
any thoughts?
Old Dec 26, 2003 | 01:28 PM
stRodda's Avatar
Default Re: (bad-monkey)
im thinking i have a throttle problem. but is it electrical or because of the tb?
i noticed, normally when i cruise, i can keep my foot basically still. the throttle chanegs .1% up or down usually. but when i felt the jerkiness... i was in 5th, 70ish... and the throttle% was jumping between 9 and 14%. btw, i was reading all this off the vafc.
Old Dec 26, 2003 | 02:01 PM
junbb1's Avatar
Default Re: (stRodda)
from experience i would say that you have a bad EGR valve
Old Dec 26, 2003 | 04:19 PM
LudeyKrus's Avatar
Most have said it's from a bad knock sensor, and some from the EGR. What you are experiencing is the infamous "Prelude Hesitation"
Old Dec 26, 2003 | 08:58 PM
stRodda's Avatar
Default Re: (LudeyKrus)
heres another thing that happened, maybe this with further solidify your conclusions. today i was racing my friend and randomly the check light would come on. thing is, whenever it did, my throttle problem would go away... and along with that, the vafc would show a constant 0% throttle, even if i was flooring it.
if its the egr, im assuming i can just get a new one. but for the knock sensor, can i just disable it? or is there a way to fix that problem? i running a p72 if it makes a difference.
Old Dec 26, 2003 | 11:02 PM
stRodda's Avatar
ok i checked the codes. i was getting quite a few. 3, 7 and 21(map, tps, vtec solenoid valve).
now what do i have to do to fix this crap?
i dont really know what those do, but its obvious theyre affecting it somehow. but whats with the vtec solenoid? what does that affect? ive nver had a problem with vtec engaging or anything like that.
Old Dec 27, 2003 | 04:53 AM
junbb1's Avatar
pull your vafc off. i bet you have a problem with that. a tps code is very rare for a honda. that will be easy to start with and may eliminate all 3 of your problems
Old Dec 27, 2003 | 07:11 AM
LudeyKrus's Avatar
i would have said the TPS when you said the 0% throttle thing.
Like he said, unhook the VAFC; it may just be b/c of some bad wiring.
Old Dec 27, 2003 | 11:03 AM
stRodda's Avatar
i tried that. i turned the car off and unclipped the vafc. started it back up and the same problem. i was just sitting in neutral watching it idle and it was jumping around. from over 1000rpm down to 4-500, like is was going to stall out.
Old Dec 27, 2003 | 11:44 AM
LudeyKrus's Avatar
no, not unclip it; actually go through the wiring and look at everything. If one is grounding out b/c it's not insuldated good enough, then it's gonna cause a lot of problems.
Old Dec 27, 2003 | 11:54 AM
stRodda's Avatar
oh ok. im sure it very easy to do that. but im not the one who wired it up and i dont know alot about doing that kind of stuff. but i think i found a solution until i can take it to the shop monday.
i went on hoping it was the tps causing all the problems. i was reading through the haynes and it mentioned that if a code7 is thrown the ecu will revert back to an artificial stock mode and i will regain some performance... which i believe i was feelings. whenever the check light went on, the car would feel better. so assuming there is some back wiring or a bad tps, i just unplugged it and now it runs fine. i know its not running like it should, but its great compared to what it was before.
if what i did was a big no-no, what else can i do. im not a complete idiot but i dont want to start messing with ecu wiring if that would be necessary.
and thanks for all the help. i get so much more advise on this forum than all others combined.
Old Dec 27, 2003 | 12:24 PM
stRodda's Avatar
well it looks like i was trippin a little bit. i reset the ecu and drove around for a bit... real hard, trying to make anything that was going to go wrong, go wrong. and the only code i got was the tps. so its either wiring where the connector is or in the ecu where the vafc was installed. either way, im going to let the shop deal with it, since theyre the ones that put it in. and of course, theyll be doing it for free.
95accordian
Feb 7, 2014 12:02 PM
wes7side5o
15
Mar 16, 2007 06:47 AM
RTICETVSL
Jan 19, 2004 09:57 PM
