obd-1 p28 ecu with b16 1st gen
Old Dec 25, 2003 | 04:08 PM
aVstAr's Avatar
Default obd-1 p28 ecu with b16 1st gen
I was wondering if I could use a obd1 p28 ecu with my setup. What other parts would I need? obd1 distrubitor? obd0-obd1 harness? Also, by going obd1, does that mean I run 1 o2 sensor instead of 2? Pls lemme know.
Old Dec 26, 2003 | 02:48 AM
aVstAr's Avatar
Default Re: obd-1 p28 ecu with b16 1st gen (avscrx)
bump
Old Dec 26, 2003 | 08:37 AM
4crx4me's Avatar
1 four wire o2, yes. OBD1 ecu, and dizzy. You are on the right track.
Old Dec 26, 2003 | 03:16 PM
aVstAr's Avatar
Default Re: obd-1 p28 ecu with b16 1st gen (4crx4me)
Is this all? Or would i need the jumper harness?
Old Dec 26, 2003 | 03:48 PM
4crx4me's Avatar
Yes obd0-obd1 jumper
obd1 dizzy
obd1 ecu
obd1 injectors and obd1 injector clips( or you can still use the obd0 injectors if you keep the obd0 injector clips and the resistor box.)
Old Dec 26, 2003 | 07:41 PM
YumVTEC's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by avscrx &raquo;</TD></TR><TR><TD CLASS="quote">Is this all? Or would i need the jumper harness?</TD></TR></TABLE>
you need something to convert your obd0 ecu plugs to obd1 plugs, so yes a jumper harness would fit the bill. unless you want to cut off your obd0 plugs and solder on obd1 ones, but that would be a huge PITA.
dc5itracer
10
Mar 26, 2011 10:29 AM
Dkahn18
Feb 18, 2009 04:41 PM
tsr2
14
Dec 2, 2006 10:23 AM
91dxcrx
Jan 22, 2006 09:27 AM
r7
Mar 14, 2003 10:08 AM
