JDM ITR cat?
ive posted about this before but i need help ASAP!!
k i got 96 civic couope w/ c5 motor, i just bought a jdm dc header and civic apexi world sport cat-back. Now ive been lookin for someone to make me a custom 2.5in cat to hook up to everything but no luck, so i was wondering if the jdm type r header would fit in. i know it would hook up to the header and pretty sure it would hook up to the exhaust but i dunno if it the right length, im thinking it would need to be about a 13inche cat (not positiive) so let me know guys!!!!!!
I think you might be looking for carsound cat 94066/93506 (oval) or 53006 (round). I don't remember the exact length but they fit on JDM 4-1 headers matched with most b-pipes.
Contact SMSP on this board or Mike from IPS Racing for a bolt up cat. I wish i would have went this route when i bought mine.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Boges »</TD></TR><TR><TD CLASS="quote">I think you might be looking for carsound cat 94066/93506 (oval) or 53006 (round). I don't remember the exact length but they fit on JDM 4-1 headers matched with most b-pipes.
Contact SMSP on this board or Mike from IPS Racing for a bolt up cat. I wish i would have went this route when i bought mine.</TD></TR></TABLE>
ive emailed smsp, how can i contact mike at ips racing???
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SleepnCiViC »</TD></TR><TR><TD CLASS="quote">how long is the JDM type r cat???</TD></TR></TABLE>
JDM cat is about 12 inches (11.81 i think)...which is much shorter than the US length cat.
and
http://www.ipsracing.com/
and
Take a look at the T1R Race Cat (Really just a cat by-pass) it is 2.5" and bolts right up to the JDM Spec DC header. Check out http://www.aj-racing.com/typeo...6.htm This is where I bought mine from.
EDIT: It bolted up perfectly on my ITR with DC JDM header, and T1R mid-pipe/N1 Muffler.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SleepnCiViC »</TD></TR><TR><TD CLASS="quote">cool cool, the jdm type r cat has an o2 bung after the cat, correct??</TD></TR></TABLE>I think only in the header, since their ECU only looks for a primary 02 sensor.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Boges »</TD></TR><TR><TD CLASS="quote">I think only in the header, since their ECU only looks for a primary 02 sensor.</TD></TR></TABLE>
This is correct, same goes for Euro spec R's
you need a udsm sized cat (17") to mate the jdm 4-1 to a usdm length exhaust (apexi worldsport). the cat needs a 2.5 flared tip to fit the collector. i got mine from mike at ips
you have an obd2 car, if you stayed obd2 with the swap then you will need an o2 bung welded into the cat as well. if you converted to obd1 then you dont have to worry about it.
damn well what should i do b/c i am currently runnin 2 o2 sensors, in my civic w/ c5 motor, ill be able to have on in the header but i dont know what to do w/ the secondary, is it a must have?? and how much yo sell the jdm cats for, they should fit for what i need
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SleepnCiViC »</TD></TR><TR><TD CLASS="quote">damn well what should i do b/c i am currently runnin 2 o2 sensors, in my civic w/ c5 motor, ill be able to have on in the header but i dont know what to do w/ the secondary, is it a must have?? and how much yo sell the jdm cats for, they should fit for what i need</TD></TR></TABLE>
If you get a carsound then it will solve your problem. You won't need to make any additional modifications. Mike M at IPS Racing has the cat you need to bolt it right up.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by IGGY »</TD></TR><TR><TD CLASS="quote">
If you get a carsound then it will solve your problem. You won't need to make any additional modifications. Mike M at IPS Racing has the cat you need to bolt it right up.</TD></TR></TABLE>
i sent him an email 3 days ago, and havent headr from him, im it jsut due to the holidays but do you know a more direct link to him??
