who knows wat parts i need to swap a 95 gsr motor into a 90 civic???
Old Sep 24, 2001 | 08:43 AM
PROFILE EK4's Avatar
New User
Default who knows wat parts i need to swap a 95 gsr motor into a 90 civic???
like the title topic says...i know i need the motor mount kit....and my question is...what shift linkage do i need...ive heard u can use a gsr shift linkage but it needs to be cut and welded....and what wire harness can i use....ive heard that i need the 88 91 crx si harness...any help would be aprreciated..thanks
Old Sep 24, 2001 | 09:13 AM
RyanR's Avatar
Default Re: who knows wat parts i need to swap a 95 gsr motor into a 90 civic??? (PROFILE EK4)
Don't be lazy, do a search. Either in this forum or the EF Civic/CRX forum. Also check out http://www.hasport.com
Old Sep 24, 2001 | 12:38 PM
Blown90hatcH's Avatar
Get a HCP mount kit with the adjustable linkage. Keep all the stock GSR distributor, injectors, and ecu. Get a cable tranny. Run a OBD0-to-OBD1 conversion harness. Add some wires and you are done. I have the conversion harnesses for 140 +shipping and the mount kit plus linkage for 410 +shipping. Let me know. You can use your stock Dx, Si, or Hf harness too. Just modify it.
Old Sep 24, 2001 | 01:23 PM
MysteryWagon's Avatar
Default Re: who knows wat parts i need to swap a 95 gsr motor into a 90 civic??? (Blown90hatcH)
How difficult is it to modify the Dx harness for the B18c swap. I am getting the JDM OBD1 engine o I will not have to worry about that.
Also how can you get that stuff all so cheap?
[Modified by ShaggenWaggon, 6:23 PM 9/24/2001]
Old Sep 25, 2001 | 01:03 PM
Default Re: who knows wat parts i need to swap a 95 gsr motor into a 90 civic??? (ShaggenWaggon)
It isnt too bad. When I do it, I solder everything and loom and tape everything. Takes me about 5 hours to do it very clean. If someone is in a rush...I can do it in 2 hours. If you are running the OBD1 JDM swap, you WILL need to run one of my harnesses in order to keep the OBD1 injectors, distributor, and ecu. Other wise, you have to run the Pr3 ecu, 1st Gen B16a distributor and injectors. All of my harnesses come with instructions and parts lists to finish this correctly. They are a good set of instructions I think. Sold about 15 harnesses and had all good remarks on the instruction accuracy and detail. I do alot of business with HCP. I am an authorized distributor of HCP for all of northern Cali. Let me know if I can help.
Jason
Enjoibaker
Sep 6, 2011 09:21 PM
BishopXIII
Dec 20, 2005 06:10 PM
bjfisher
Dec 16, 2005 09:44 AM
Hatchbizzack
Oct 31, 2004 06:56 PM
mbsi
18
Apr 3, 2003 02:31 PM
