95 h22 in a 96 accord lx wiring Q?
Old Dec 25, 2003 | 09:14 AM
racerboyb18c1's Avatar
Default 95 h22 in a 96 accord lx wiring Q?
i have a 95 h22 in a 96 accord lx runs great on the f22 ecu but when you plug in the h22 ecu runs like shat ne thing needs to be re- pind? ive heard o2 and somthing are different but need experienced tech help let me know thank you. throughing miss fireing codes also but just with h22 ecu and i know it works cus it came out of my car and i double checked thanks, obd2 p13
Old Dec 25, 2003 | 09:56 AM
HAccord's Avatar
Default Re: 95 h22 in a 96 accord lx wiring Q? (racerboyb18c1)
Hey man you need to check out h22.org! You need to switch a6 with a11~ its the o2 heater sensor and egr. they are switched on the accords! As for why it runs better on the stock ecu... is probable because you have a p13 automatic ecu!~ I had the same thing.. be sure its a manual ecu! otherwisw it wont let you rev it past 3500 or so. I had the same problem
Old Dec 25, 2003 | 09:57 AM
HAccord's Avatar
oh and because of the fact that i see you said obdII p13.. the 1995 is set up for OBDI ! thats probable was the biggest problem
Old Dec 25, 2003 | 10:38 AM
Default Re: 95 h22 in a 96 accord lx wiring Q? (HAccord)
well the car is set up to a obd2 wiring harness from the accord , also its a obd2 car
Old Dec 25, 2003 | 02:48 PM
HAccord's Avatar
yeah unless you changed over the motor to OBDII... than everything is flucked! you should have did an OBDII to I conversion
01sdime
Jul 13, 2023 01:18 PM
import_tuner13
Nov 12, 2011 01:03 AM
dvp95
Jul 9, 2011 05:29 PM
racerboyb18c1
Dec 29, 2003 02:52 PM
racerboyb18c1
Nov 21, 2003 09:51 AM
