Pulling metal chunks from tranny (5 pics)
Old Dec 24, 2003 | 11:25 PM
crazy eyez killa
Guest
Posts: n/a
Default Pulling metal chunks from tranny (5 pics)
Differential went bust, unfortunately the diff is at a friends house so no pics, but I got bored so here are some pics
Heres some chunks I got out of my B16 tranny
Old Dec 25, 2003 | 02:35 AM
sirminder's Avatar
Default Re: Pulling metal chunks from tranny (dupalala)
You should place some sort of support on the engine while while the other mount is off. But for doing it yourself. Wish I had the tools, and friends to help me out.
Old Dec 25, 2003 | 12:22 PM
crazy eyez killa
Guest
Posts: n/a
Default Re: Pulling metal chunks from tranny (sirminder)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sirminder &raquo;</TD></TR><TR><TD CLASS="quote">But for doing it yourself. Wish I had the tools, and friends to help me out.</TD></TR></TABLE>
Mannn if tranny work wasn't so damn expensive, I would love for a shop to do it. Wish me luck
Old Dec 25, 2003 | 01:03 PM
vtekthis's Avatar
stock diff= weakest point, quife= great i love mine
Old Dec 25, 2003 | 07:01 PM
Mohudsolo's Avatar
Default Re: (vtekthis)
In pic #3 the roller bearing that appears to be for the mainshaft looks to be seriously off center. Is it OK? Did the diff case blow up or the gears? While you have it apart, you may want to check out the synchronisers and make sure they are all in good shape. Hose down the case and all the parts you keep really well to make sure all the little bits are cleaned out. Hate to have a repeat performance.
Old Dec 25, 2003 | 10:19 PM
crazy eyez killa
Guest
Posts: n/a
Default Re: (Mohudsolo)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mohudsolo &raquo;</TD></TR><TR><TD CLASS="quote">In pic #3 the roller bearing that appears to be for the mainshaft looks to be seriously off center. Is it OK? Did the diff case blow up or the gears? While you have it apart, you may want to check out the synchronisers and make sure they are all in good shape. Hose down the case and all the parts you keep really well to make sure all the little bits are cleaned out. Hate to have a repeat performance.</TD></TR></TABLE>
LOLOL it looks bad in the pic but its really just a washer thats sitting on the bearing that isnt sitting perfectly. Synchros all look good, im surprised because I hear a lot about bad synchros in B16 trannys.
Yes im going to do my best cleaning it out, hence the carb cleaner in some of the pics. **** no i dont want to do a repeat performance.
Jay J
Mar 29, 2006 07:44 AM
J.nguyen
Jan 3, 2006 08:31 AM
cyris3d
Sep 15, 2005 02:58 PM
StErN
Nov 21, 2004 12:38 PM
nevin
Mar 24, 2004 12:00 PM
