Which suspension is good?
Old Dec 24, 2003 | 08:43 PM
Moonbus's Avatar
Default Which suspension is good?
Hello Guys/Girls,
First of all, Merry Christmas!!
I have a question. I have a 98 Spec ITR, and the only modification I have is Mugen exhaust system and Spoon Intake. I recently feel the suspension is falling on me as it bottoms out easily.... so had been thinking to get a new set of suspension.
Hope to get some recommendation on suspension. 95% of the time the car sees road use, sometimes aggressive, but rarely go on track. I would like something that is a bit stiffer than the OEM suspension, but will not be too harsh on normal road. What would u recommend??
Thanks very much!!!
Old Dec 24, 2003 | 08:45 PM
BlueR's Avatar
Default Re: Which suspension is good? (Moonbus)
depends on your budget
Old Dec 24, 2003 | 08:48 PM
Moonbus's Avatar
Default Re: Which suspension is good? (BlueR)
Hi, I am planning to spend less b/w 700-1000 USD.
Old Dec 24, 2003 | 08:51 PM
BlueR's Avatar
you want simple spring/shock combo or full coilovers?
Old Dec 24, 2003 | 08:52 PM
Ferrell's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Moonbus &raquo;</TD></TR><TR><TD CLASS="quote">Hi, I am planning to spend less b/w 700-1000 USD.</TD></TR></TABLE>
Tein basic.
Old Dec 24, 2003 | 08:55 PM
BlueR's Avatar
Default Re: Which suspension is good? (Ferrell)
Tein SS can also be had for less than 1000...
most simple spring/shock combos will end up lowering your car
and it may not even be a performance upgrade from a new OEM setup...
but i recommend Bilsteins for shocks
Old Dec 24, 2003 | 09:11 PM
Moonbus's Avatar
I am looking for a spring/coil combo, would like to lower the car a bit as well
Sounds like Tein is not really better than the OEM set?
Old Dec 24, 2003 | 09:18 PM
BlueR's Avatar
IMHO, given your budget...i would go with:
bilstein shocks http://www.shox.com
spoon springs or kgmm springs http://www.randdmotorsports.com
hth
Old Dec 25, 2003 | 10:12 AM
paRRRker's Avatar
konis and gc's with spring rates of your choice to suit your needs. around $850 for both.
Old Dec 25, 2003 | 10:19 AM
Big Phat R's Avatar
Either try used Mugen Lowdowns or a Ground-Control type setup with stiffer springs and shocks.
I used Ground Control coilover sleeves with Eibach ERS springs and Bilstein shocks for a long time before switching to Spoon coilovers.
They are the best bang for the buck.
Wanna buy my old set?
Old Dec 25, 2003 | 10:29 AM
RagingAngel's Avatar
Since you are in Japan, you have the potential to pick up a lot of good dampers used.
I'd go with the Spoon Sports coilovers with a 14/12kg spring front/rear.
If you ever need them rebuilt, just pop them over to Ogikubo.
Old Dec 25, 2003 | 10:57 AM
EJ1_519
Guest
Posts: n/a
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Ferrell &raquo;</TD></TR><TR><TD CLASS="quote">
Tein basic.</TD></TR></TABLE>
Agreed. Perfect for the street if you don't plan on doing any hardcore autoX. Tein Basic is my next setup in my car
Old Dec 25, 2003 | 11:15 PM
Moonbus's Avatar
Default Re: Which suspension is good? (EJ1_519)
Thanks everyone for the info!! I will go check out Yahoo auction for some good deals
Old Dec 31, 2003 | 09:12 AM
Pretend-R's Avatar
Anyone try'd Whiteline handling kits? There are more and more Nissan 240SX turbo owners here that is using it...And i hear nothing bad about it...
URL: http://www.whiteline.com.au
Old Dec 31, 2003 | 09:22 AM
Kengs's Avatar
Default Re: Which suspension is good? (RagingAngel)
Like RagingAngel said, you are at an advantage since you live in Japan.
Check out the Yahoo JPN Auctions - you should be able to get a nice set of Tein or Zeal dampers for under JY80000.
Here is the link for Honda dampers/springs
http://list1.auctions.yahoo.co....html
Old Dec 31, 2003 | 09:29 AM
Kengs's Avatar
Default Re: Which suspension is good? (kengs)
Case in point, there is a set of Zeal SUPER FUNCTION dampers for EG/DC2 on auction...current price is JY69000 with one day left.
http://page.auctions.yahoo.co....26608
Old Dec 31, 2003 | 09:33 AM
nsxtasy's Avatar
H-T Order of Merit
I would suggest that the stock shocks are also very good and worth considering.
Keep in mind that yours (and those of many others with lots of miles on them) are probably worn after many thousands of miles. Many folks are surprised at the difference in their suspension when they go from worn stock shocks to new stock ones, because the new ones are a lot firmer in feel.
However, one advantage of many aftermarket shocks (like Bilsteins) is that they usually last longer and come with a lifetime warranty, which may be important if you plan to keep your car for a long time.
Old Dec 31, 2003 | 10:39 AM
MK Ultra's Avatar
Default Re: Which suspension is good? (nsxtasy)
I would suggest the Bilsteins over the stock dampers mostly because of their extended longevity, but that's all I'd do. Bilstein dampers and OEM springs.
Old Dec 31, 2003 | 12:50 PM
Misfit's Avatar
Default Re: Which suspension is good? (doosu)
I would say GC's and Koni Yellows. I managed to steal my GC's for 100 bucks and Koni's for 250.
&lt;---------- Much happiness happyness happening over here.
Old Dec 31, 2003 | 10:28 PM
DarthLuder's Avatar
New User
Morton.
Old Dec 31, 2003 | 10:58 PM
Red*EG*'s Avatar
I bought Tein Flexes for the simple fact that you can run stock hight and lower it when you want, also you can set your dampering to what you need SOFT or HARD. It also has rust prevention and is only MSRP $1,430. You could get it for less. The whole kit weight is only 40 pounds.
Old Dec 31, 2003 | 11:56 PM
Kicker773's Avatar
Default Re: Which suspension is good? (blackdc2R)
moogen anyone?
Old Jan 1, 2004 | 01:17 AM
Evs-One's Avatar
Solbros Owns Me
Why!?
Not even adjustable damper
For the price you could build a custom setup with GC sleeves, custom rate Eibach springs, and Koni Yellows with GC adapters for the "full coilover" look.
This will be less than the Basics and will have dampening adjustability also. PLUS, you pick your own spring rates....I'm running 400# front and 500 lbs rear on my EG....which would be a good setup for a street driven ITR, which is heavier
Old Jan 1, 2004 | 06:18 AM
ITR764's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BlueR &raquo;</TD></TR><TR><TD CLASS="quote">depends on your budget</TD></TR></TABLE>
which is why i'm still rolln' on st00k.
Old Jan 1, 2004 | 08:03 AM
rated_r's Avatar
tein
