AEM air bypass valve, install --> where to cut the pipe?
Old Dec 24, 2003 | 05:22 PM
kool168's Avatar
Default AEM air bypass valve, install --> where to cut the pipe?
hello, i just bought an AEM air bypass valve, so now i have to install it of course, but which part of the pipe has to be cut ?
some people say it is better to placing the bypass valve on the lower part of the straight pipe closest to the filter, but somebody said in the opposite of the above statment...
and i wanna hear some feedback of the people who has the AEM CAI and the air bypass valve
thankz
Old Dec 24, 2003 | 05:28 PM
skafia's Avatar
25 Year Member
Default Re: AEM air bypass valve, install --> where to cut the pipe? (kool168)
The bypass valve didn't come with directions?
Old Dec 24, 2003 | 05:36 PM
JjuuN R's Avatar
definately shoulda came with instructions. mine is located right before it bends to go downward, about 4 inches south of the distributor.
i'm about to replace it with the J's though, heard nothing but good things about that intake
Old Dec 24, 2003 | 08:57 PM
Bbasso's Avatar
I would not even bother with the Bypass, I have had mine for nearly 3 years and not a problem. You have to use your head when it comes to deep water but that should not be a problem. I have been through plenty of rain storms without incident.
Old Dec 24, 2003 | 09:01 PM
BlueR's Avatar
Default Re: AEM air bypass valve, install --> where to cut the pipe? (Bbasso)
whats wrong with a little more protection...$50 or blown motor?
anyways, cut the intake pipe as far away from the throttle body as possible, IE right where the stock airbox used to be, you should have plenty of room there
Old Dec 24, 2003 | 09:26 PM
JjuuN R's Avatar
Default Re: AEM air bypass valve, install --> where to cut the pipe? (BlueR)
Old Dec 24, 2003 | 10:14 PM
kool168's Avatar
Default Re: AEM air bypass valve, install --> where to cut the pipe? (JUN.R)
it came with instruction, but i did a serach on the web, and people said they did wut the instruction tells but it decrease the hp...
that's why i post here and wanna see people's opinions
haven't decide gonna cut the pipe in half yet, since i dun wanna cut 200 bucks in half and reduce the power
if the bypass valve really not worth to cut the pipe, i might just refund it
Old Dec 24, 2003 | 10:58 PM
py1188's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by kool168 &raquo;</TD></TR><TR><TD CLASS="quote">it came with instruction, but i did a serach on the web, and people said they did wut the instruction tells but it decrease the hp...
if the bypass valve really not worth to cut the pipe, i might just refund it</TD></TR></TABLE>
Isn't the point insurng the safety of your motor, not the increase/decrease in .xx hp??
Old Dec 24, 2003 | 11:18 PM
JjuuN R's Avatar
J's racing short ram
Old Dec 28, 2003 | 10:28 PM
friedsqrl's Avatar
Default Re: AEM air bypass valve, install --> where to cut the pipe? (py1188)
ahh the ahh the the bypass valve i hear needs proper installation to be most effective.
Old Dec 28, 2003 | 10:32 PM
DsITR's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BlueR &raquo;</TD></TR><TR><TD CLASS="quote">whats wrong with a little more protection...$50 or blown motor?
A friend of mine sucked some piece of odd material (ie rock/metal) through the "motor saving" bypass valve....toasted his H22
The "Foam" material of the bypass valve isn't very durable, and tears very easily.
The car was a prelude, however I'd still be concerned...
Old Dec 29, 2003 | 01:08 AM
Kicker773's Avatar
Default Re: AEM air bypass valve, install --> where to cut the pipe? (DsR)
have one of those..their ok.. but switchin to a better cai soon.. hopefully after the winter time.
Old Dec 29, 2003 | 03:29 AM
kool168's Avatar
Default Re: AEM air bypass valve, install --> where to cut the pipe? (Kicker773)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Kicker773 &raquo;</TD></TR><TR><TD CLASS="quote">have one of those..their ok.. but switchin to a better cai soon.. hopefully after the winter time. </TD></TR></TABLE>
wut's better CAI?
em1foyo
Jan 5, 2008 01:23 PM
PearlBlueType-S
10
Dec 25, 2005 01:34 AM
Fidelio25
Jul 4, 2004 05:41 PM
CRLude97
Jan 9, 2004 01:41 AM
hYpE-R-29
May 23, 2003 01:01 PM
