better head for a LS/VTEC swap a B16A2, or B18C3
the pr3 (b16) head flows less than 5% better than a p72 (gsr) head. the gsr head actually flows better down low. The gsr head will also give you about a .2 raise in your c/r. go with the p72.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by LsVtec92Hatch »</TD></TR><TR><TD CLASS="quote">the pr3 (b16) head flows less than 5% better than a p72 (gsr) head. the gsr head actually flows better down low. </TD></TR></TABLE>
Where did you get this info?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by LsVtec92Hatch »</TD></TR><TR><TD CLASS="quote">or you can get the skunk2 manifold for the GSR head so it flows just as good AND has more compression.</TD></TR></TABLE>
Nice come back. Not only does Skunk2 make an IM(type R), but theres STR,eldebrock....,Rev Hard just came out with one, and several other companies redrill Type R Im's just like Skunk2 with a little more aggressive port and polish.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by XratedSi »</TD></TR><TR><TD CLASS="quote">
Where did you get this info?</TD></TR></TABLE>
from a flow chart.....
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Drag_Racer_DRU »</TD></TR><TR><TD CLASS="quote">the gsr manifold
Aguilar still runs one.
</TD></TR></TABLE>Aguilar still runs one.
according to that chart.. the 2 IM's are fairly similar,.. it all depends if u want more airflow at low rpm (gsr) or.. want more mid/high airflow (b16) buuuuuut.. i'd say aftermarket IM's take my vote as delivering the best overall performance.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Drag_Racer_DRU »</TD></TR><TR><TD CLASS="quote">go with the b16a head so you can run a type R manifold, the gsr manifold
thats the most retarded statement ive heard in a while.
</TD></TR></TABLE>thats the most retarded statement ive heard in a while.
back on topic to the heads and airflow..
consider the price difference.. b16 heads are way more common and because of that are starting to get cheap as peanuts.. b18c-c1-c3 whatever... try find a good deal on a fully assembled b18c head that the ppl arent charging a damn fortune for.. IMO there is not enough differences between the two heads to go for the more expensive b18c..
i am not trying to contradict anyone elses knowledge but what extreme diff are u going to get with .2 c/r increase?? if the b16 flows alil less than 5% better (which is easily overcome with a aftermarket I.M) and keeps the compression the same.. why bother about a .2 increase in compression and spending hundreds of more dollars?? i would just go with the b16 since its WORLDS cheaper and extremely easy to come by! my 2 cents (sorry about the novel)
Modified by 4genaccordfreak at 7:13 AM 1/11/2004
Honestly i don't trust any of the flow charts on alaniz website. If u look at the b18c5 head flow chart it show that it flows 151 cfm @ 10" of h20, now look at the b16 head comparisons, it shows that it flows exactly the same amount as the c5 head- 151 cfm @ 10" of h20. How could that be?
</TD></TR></TABLE>Honestly i don't trust any of the flow charts on alaniz website. If u look at the b18c5 head flow chart it show that it flows 151 cfm @ 10" of h20, now look at the b16 head comparisons, it shows that it flows exactly the same amount as the c5 head- 151 cfm @ 10" of h20. How could that be?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SpdFrk »</TD></TR><TR><TD CLASS="quote">
Honestly i don't trust any of the flow charts on alaniz website. If u look at the b18c5 head flow chart it show that it flows 151 cfm @ 10" of h20, now look at the b16 head comparisons, it shows that it flows exactly the same amount as the c5 head- 151 cfm @ 10" of h20. How could that be?</TD></TR></TABLE>
I overlapped the 2 for another thread awhile ago:
Either the R head is way overated, or Alaniz's charts are no good...
What do you guys think of the B17 head and intake from the 92+ GSRs? Whats the difference between the B17 head and the GSR, B16 and type R head? I have a an eg sedan with a a B18b1 swap and I want to make it LS Vtec but I'm not sure which head to go with. My buddy is selling me a B17 head with the intake and braided line ready for the LS vtec swap, all I would need is the cpu for $450. Any opinions or suggestions? Thanks for your help
