B16A with CTR pistons??
Old Dec 24, 2003 | 11:53 AM
hondaboyB18C1's Avatar
Default B16A with CTR pistons??
Using CTR pistons in a B16A lowers piston-valve clearence. Is there enough room for a thin headgasket or a 12.0 mm lift cam or even a deccked block????
Old Dec 24, 2003 | 03:56 PM
Dancing is Forbidden's Avatar
Default Re: B16A with CTR pistons?? (hondaboyB16)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hondaboyB16 &raquo;</TD></TR><TR><TD CLASS="quote">Using CTR pistons in a B16A lowers piston-valve clearence. Is there enough room for a thin headgasket or a 12.0 mm lift cam or even a deccked block????</TD></TR></TABLE>Clay it to be sure but I think it will work fine. But I would still clay it to be 100% sure.
Old Dec 24, 2003 | 04:00 PM
b16powwer's Avatar
whats up man, i have the same setup, and i am using skunk2 stage 2 cams w/mugen head gasket, works fine for me. good luck
Old Dec 24, 2003 | 04:34 PM
C8V6C's Avatar
Default Re: B16A with CTR pistons?? (b16powwer)
What kinda times and hp are you pullin "B16powwer?"
Old Dec 24, 2003 | 04:47 PM
rev-speed's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by b16powwer &raquo;</TD></TR><TR><TD CLASS="quote">whats up man, i have the same setup, and i am using skunk2 stage 2 cams w/mugen head gasket, works fine for me. good luck</TD></TR></TABLE>
how thick is ur mugen head gasket?
what compression ratio r u running?
did u mill the head?
Old Dec 25, 2003 | 05:33 PM
Default Re: B16A with CTR pistons?? (tomtomloc)
Head or block is not milled. mugen head gasket is I think .027?? 10.9 with CTR pistons
Old Dec 28, 2003 | 10:44 AM
bump
91teg
64
Aug 22, 2011 03:34 PM
xDicktonesx
18
Aug 11, 2005 11:37 AM
Beezer
12
Mar 19, 2005 10:53 AM
nmhybridog
Sep 24, 2003 07:27 AM
silverCRXTC
Feb 20, 2003 01:00 PM
