PM6 in an A/T CRX? Would it blow up?
I'm in the middle of doing three or four things at once and I just want to check and see if the DPFI-MPFI is wired correctly and working before I go onto the next step. I don't want to have to buy a PM7 just to check the wiring, and then throw or give it away.
So, can I check to see if MPFI is working corrrectly by starting an AT CRX with a PM6 hooked up?
Has anyone ever done it? What will happen? Will it blow up or even START without the two pins for the AT in the ECU?
hksdrager
May 11, 2007 07:58 PM
too much vtAK
Oct 29, 2006 12:52 PM
koto SM2
11
Mar 29, 2004 04:03 AM
