Anyone here get the VAFC harness from Boomslang?
Old Dec 24, 2003 | 11:00 AM
Se-rv-Tak's Avatar
Default Anyone here get the VAFC harness from Boomslang?
I was curious to see if any of you got a VAFC harness from boomslang, and exactly what it consists of? what is the purpose of it? etc. etc.?
Old Dec 24, 2003 | 04:29 PM
Thagreybomber's Avatar
Default Re: Anyone here get the VAFC harness from Boomslang? (Soon2B18Boost)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Soon2B18Boost &raquo;</TD></TR><TR><TD CLASS="quote">I was curious to see if any of you got a VAFC harness from boomslang, and exactly what it consists of? what is the purpose of it? etc. etc.?</TD></TR></TABLE>
I'm wondering the same thing.
Old Jan 8, 2004 | 10:24 AM
Default Re: Anyone here get the VAFC harness from Boomslang? (Thagreybomber)
Guess no one has one
Old Jan 8, 2004 | 10:50 AM
IN VTEC's Avatar
Default Re: Anyone here get the VAFC harness from Boomslang? (Se-rv-Tak)
It serves the same purpose as the Field's VTEC harness.
It allows you to wire the VTEC/AF controller to a harness to make it easier to install and uninstall.
A side benefit is that it also makes it easier to use a DVOM to check voltages, continuity, etc. when you need to troubleshoot in that area.
Old Jan 8, 2004 | 02:50 PM
AzG35's Avatar
The purpose of the VTEC controller harnesses is that you don't have to cut into the factory wiring. You can leave everthing in tact and don't have to worry about soldering stuff back if you put everything back to stock.
Old Jan 8, 2004 | 07:11 PM
Sounds and seems logical...but does anyone have pictures of one. The wiring, from the VAFC itself, doesn't allow it to be mounted very far...now, if one were to use the extra wiring that came with it (the wiring that one has to cut/splice/soldier) then it allows the VAFC to be mounted just about anywhere from the middle to the right side of the front cabin.
Old Jan 9, 2004 | 09:20 AM
Se-rv-Tak's Avatar
oh ok, so is it worth the $125? extra
crazi_E
Jul 18, 2007 03:57 PM
crazi_E
Northeast (Sales)
Jun 26, 2007 10:21 AM
ModlesSI
Feb 11, 2003 05:18 PM
Chris N
Dec 17, 2002 03:39 PM
