timing belt change......when?
Old Sep 23, 2001 | 10:19 PM
hobo79's Avatar
New User
Default timing belt change......when?
i have a 98 civic ex coupe with 54K and was wondering whether a timing belt change is best at 60K or 90K......cuz some cars go til 09 and some don't, can someone please clarify that. THANKS!
Old Sep 23, 2001 | 10:26 PM
Slain's Avatar
Default Re: timing belt change......when? (hobo79)
had my changed around 90k along with water pump, clutch, and i believe accesories belt
Old Sep 23, 2001 | 10:33 PM
X2BOARD's Avatar
Default Re: timing belt change......when? (Slain)
Every 70K for me.... On your next one you can slap on some cam gears , have the cover cut and get free inspection of the timing belt anytime you want....
Old Sep 24, 2001 | 06:54 AM
shamoo's Avatar
Will you make something up for me please?
Default Re: timing belt change......when? (X2BOARD)
Honda recommends it after every 90K miles. This includes the timing belt, water pump, drive belt, and a few other things like the standard oil change and whatnot.
For cars year 2000 and newer, they recommend every 100K miles. I had my 97 LS done at 94K miles and it was still in good shape. But, especially with a timing belt, better safe than sorry. If one goes when you're driving, say goodbye to your motor.
Old Sep 24, 2001 | 10:01 AM
E Swift's Avatar
Default Re: timing belt change......when? (shamoo)
I changed mine at like 115,000 miles.
Old Sep 24, 2001 | 10:09 AM
97LudeSH's Avatar
New User
Default Re: timing belt change......when? (420TegLS)
In my previous car, 90 Celica GT, It hadn't been changed till 150k miles The timing belt was in rough shape. The engine was a non-interferance type anyways.
Mike
Old Sep 24, 2001 | 10:04 PM
SlickRedSi's Avatar
New User
Well to answer your question, I didn't change mine until about 110K on my older Honda. They say that when your car hits 100K, that it would be a good time to change the timing belt. Also, while you are down there, you should change the water pump. Probably won't be a bad idea to change the belts as well.
For the new new Hondas/Acuras, they come with a timing chain so they will never need replacing unless you really abuse your engine and just plain wear out the timing chain.
ginahoy
Sep 1, 2014 05:02 AM
square_1
13
Mar 7, 2007 10:10 AM
TeGGY_LS
Mar 5, 2004 11:28 PM
civickidd99
Aug 11, 2003 01:54 PM
N~FaMouSKhMerBoi
Jul 3, 2003 02:55 PM
