loss Of HP?
Old Dec 24, 2003 | 03:48 AM
movenu's Avatar
Default loss Of HP?
Right now I know as much about cars as I do about plasma physics but I'm trying to learn. Why is it that you lose 10-15% HP between what the engine produces and what you have at the wheels. Is it because stock valve trains, header, etc. are inefficient?
Old Dec 24, 2003 | 06:25 AM
Mikey3000's Avatar
Default Re: loss Of HP? (movenu)
no, its because of the transmission. through the gearing of the transmission and friction that happens in the transmission, you lose power.
Old Dec 24, 2003 | 06:40 AM
rapid_roy's Avatar
"Mechanical losses"
Cheers,
Roy
Old Dec 24, 2003 | 11:29 AM
Kendall's Avatar
You also have to consider losses due to to unsprung weight. Expect it to be about 14% on a front wheel drive car. It's even more on a rear wheel drive car.
Old Dec 24, 2003 | 11:50 AM
rapid_roy's Avatar
Default Re: (dc231)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dc231 &raquo;</TD></TR><TR><TD CLASS="quote">You also have to consider losses due to to unsprung weight. Expect it to be about 14% on a front wheel drive car. It's even more on a rear wheel drive car.</TD></TR></TABLE>
What?
14%!? 14% of what? Upsrung weight accounts for a 14% decrease in power? Shaved ice in Siberia? Bong water prices in Amsterdam?
The 14% you refer to is from mechanical losses, as was already stated. It's not from unsprung weight, it's from the friction of all those pieces turning together.
Cheers,
Roy
Cheers,
Roy
Mr.E.G.
Mar 20, 2007 09:45 AM
ViZ
Jan 3, 2004 08:47 PM
fire7882
Apr 18, 2002 10:33 AM
11k-redline
Aug 31, 2001 01:50 PM
