Going 84mm, do I need fuel management if not boosting yet?
Old Dec 23, 2003 | 09:15 PM
Stock@$$GSR's Avatar
Default Going 84mm, do I need fuel management if not boosting yet?
For my '94 GSR, I'm getting it sleeved and bored out to 84mm and keeping my 10:1 compression ratio. Will I need fuel management for this, or will my stock ECU be able to compensate? I'm eventually planning on buying Hondata, FPR, and injectors when I boost, but I would rather not buy now if I can hold out. Thanks.
Old Dec 23, 2003 | 11:44 PM
TeStUdO's Avatar
Default Re: Going 84mm, do I need fuel management if not boosting yet? (jerseykid609)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jerseykid609 &raquo;</TD></TR><TR><TD CLASS="quote">stock fuel set up is for stock bore you will need if anyhting more fuel in the motor otherwise it will run lean </TD></TR></TABLE>
I think it will run fine NA with the oversize bore. It might run a little lean at some spots but I think the ECU will compensate on the most part.
Old Dec 24, 2003 | 09:23 AM
karmannghia's Avatar
Default Re: Going 84mm, do I need fuel management if not boosting yet? (Stock@$$GSR)
Get an aftermarket chip and burn it in while running stock. Most chips are running a little rich....
Old Dec 24, 2003 | 10:07 AM
System-7's Avatar
how about this. I'm gettin my block back, it is gonna be sleeved to 84mm. will my LS Ecu which was dyno'd tuned with Hondata compensate?
Old Dec 24, 2003 | 12:48 PM
earl's Avatar
Default Re: (System-7)
Any change and you really need to retune. Better safe than sorry.
Old Dec 24, 2003 | 10:27 PM
m R g S r's Avatar
Default Re: (earl)
If the compression is going to be the same I think that it will be fine.
Old Dec 24, 2003 | 10:35 PM
Ek00fbp's Avatar
I think if you have an adjustable fuel pressure regulator just turn it up a little bit to compensate for the bore. I dont remember exactly what fuel pressure 2.0 liters usually run.
EJCivJdM93
May 23, 2005 06:39 PM
idle
Mar 10, 2005 11:21 AM
busakiller
Aug 8, 2004 08:02 PM
arsenaldragster
May 28, 2003 10:44 AM
AlterEgo
Feb 26, 2003 08:20 AM
