WHATS THE BEST AND CHEAPEST B16 ALL MOTOR SETUP!!!!!!!!!!!!!!!!!!!!!!
IM THINKING
CTR PISTONS $250
JDM ITR HEADERS $300
ITR INTAKE MANIFOLD $250
HONDATA S100 $230
450DSM $150
TUNEING 250
I WANT TO PUT A B16 ALL MOTOR MONSTER SETUP IN A EK HATCH I HOPE I CAN MAKE OVER 200HP!
CTR PISTONS $250
HONDATA S100 $230
450DSM $150
TUNEING 250
How can you have the "BEST" and "CHEAPEST" b16 all motor setup?
Those two words do not go together in building a b16 all motor....
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tomtomloc »</TD></TR><TR><TD CLASS="quote">IM THINKING
CTR PISTONS $250
HONDATA S100 $230
450DSM $150
TUNEING 250
</TD></TR></TABLE>To get over 200whp You are going to need MAJOR HEAD WORK. Major machining. Major bottom end work. Id shoot for 150 whp with the mods you've listed.
CTR PISTONS $250
HONDATA S100 $230
450DSM $150
TUNEING 250
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EF9_SiR »</TD></TR><TR><TD CLASS="quote">To get over 200whp You are going to need MAJOR HEAD WORK. Major machining. Major bottom end work. Id shoot for 150 whp with the mods you've listed.</TD></TR></TABLE>
150????? that's it???
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by trustbuddy »</TD></TR><TR><TD CLASS="quote">
</TD></TR></TABLE>maybe 160, but not a whole lot more. My friend has a b16a with the same mods (and more) and put out 151whp.
CTR PISTONS $250
HONDATA S100 $230
450DSM $150
TUNEING 250
this set up of yours will not come clost to 200whp
it will probably with about about 160whp or so
to make 200 hp you will need to pp the head and mill it to raise cr to at least mid 11's. the ctr pistons alone will give you 10.8cr
and get some big cams and u might be there
CTR PISTONS $250
HONDATA S100 $230
450DSM $150
TUNEING 250
I have a 91 B16A with CTR pistons (11:1), shot peened rods , ITR cams , springs , valves , TB , intake , also RC 270cc's , 41psi fp , DC sport 4-1 , Mugen chip , AEM gears , Iceman intake. 180whp , 119ft/lb . I am currently installing , JUN 2 cams , Crower springs & titanium retainers , comptech Chromoly 8.75lb flywheel , ARP rod bolts , Crower exhaust valves and a Hondatan stage 3, Possibly Probe 11:1 pistons & a spoon head gasket.. Will post new #'s when done. Thanks
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tomtomloc »</TD></TR><TR><TD CLASS="quote">dam thats sad
when i read the 200hp all motor b16 set up all it had is ef-i cams new valve job and just 11.3-1 compression and they made 200 hp to the wheels</TD></TR></TABLE>
The difference is Omniman built motors are " Badass" whereas motors built by YOU are "Sadass".......theres your HP difference.
This post is retarded...you should definately read up on building an all-motor setup. B16's are crap, the first tool to building a B16 is getting rid of the b16 block and buying an ls/crv/gsr
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by MaxBoost »</TD></TR><TR><TD CLASS="quote">This post is retarded...you should definately read up on building an all-motor setup. B16's are crap, the first tool to building a B16 is getting rid of the b16 block and buying an ls/crv/gsr</TD></TR></TABLE>
i already have a build ls-vtec with a drag turbo kit upgrade to t3/t4 .57 trim
on hondata in my 93si
i want to put a b16 monster in a ek hatch to race allmotor
and i also have a crx si with a gsr swap on 80 shot of direct port nitrous
you can build a b16 monster but it ll be very expensive,not CHEAP. first thing would be 84.5mm GE walls,good header like toda,jun3 or toda cams, 12:1 comp or higher pistons. then all the other basic stuff. and im sure you ll make 200whp or you can skip all that and just 4get about all that get rid of that block and opt for a b20 block.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by MaxBoost »</TD></TR><TR><TD CLASS="quote">This post is retarded...you should definately read up on building an all-motor setup. B16's are crap , the first tool to building a B16 is getting rid of the b16 block and buying an ls/crv/gsr</TD></TR></TABLE>
Wow, those are some pretty strong words. If he is only looking to get around 200whp out of it just stick with the B16 if you already have it. It can be done, you just need some good headwork and a little head milling, cams that are on the larger side(S2S2, Jun3), and some CTR pistons or like JE/Arias high comp pistons.
ctr pistons, 1 layer head gasket, TODA C's, P&P, Milled head, bored .25 over, ITR intake mani, Toda Header, Open DP, Js Intake, and rc inj, made for 180 in a b16a on a Dynapack. Thats roughly 200whp on a dyno jet. But if you want the costs....
Toda C's 1200
Toda Springs 300
CTR pistons w/rings 300
P&P 600
mill 100
Bore 75
ITR intake mani 300
Toda Header 900
Js Intake 180
Injectors 300
and thats 4255
And the engine management was a Power FC. So add another grand on that, Plus tuning another 500
and your around 6000. PLUS THE COST of the engine.
Toda C's 1200
Toda Springs 300
P&P 600
mill 100
Bore 75
ITR intake mani 300
Toda Header 900
Js Intake 180
Injectors 300
and thats 4255
[QUOTE=EF9_SiR]ctr pistons, 1 layer head gasket, TODA C's, P&P, Milled head, bored .25 over, ITR intake mani, Toda Header, Open DP, Js Intake, and rc inj, made for 180 in a b16a on a Dynapack . Thats roughly 200whp on a dyno jet . But if you want the costs....
QUOTE]
I thought that dynapacks read higher numbers then dyno jets???
So it would be more like 160-170whp on a dyno jet...
QUOTE]
i made 170 with a stock p30 (sir2) bottom end... with those CTR pistons you're putting in head work, some JUN 3's and the other things you listed you WILL make 200hp to the wheels! it's already been done
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tomtomloc »</TD></TR><TR><TD CLASS="quote">Omniman use parts to build that motor so people like me can build one like it!!!! </TD></TR></TABLE>
and we have yet to see or read what was used to make that setup!!! as soon as it "supsedly is to become public knowledge" i will mimic or copy the setup....
until then i do NOT believe that a B16 with STOCK PISTONS ONLY RUNNING 11.3 compression with "mild head work" MADE ANYWHERE NEAR 200 hp!!!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by chad »</TD></TR><TR><TD CLASS="quote">
i saw ur post chad.
i want to copy it too!!!
i saw ur post chad.
i'm not trying to call omniman and his associate out....but....i need proof of this....i'm not one of those internet nut swingers that believes everything i read...i am in the business and tried tons of stuff....and something is missing from this rumored 200 hp b16
key with ALL MOTOR is making it breath. that means have a good header and having someone very good in porting the head. Then you are going to need a nice big cam and tuning it very well. but key is making it breath. have fun bro but even ominimans setup made 195 but it does not mean he has never made 200 whp jus the recent motor made 195 , but by looking at the graph it looks like a curve that of a b16.
cheap and fast man that's something that is said very loosely ( is that even a word?) around here.
have fun bro hope you acheive your goal
