Can I run my H23 engine using a JDM H22 ECU??
Old Dec 23, 2003 | 08:25 PM
AndyD's Avatar
Default Can I run my H23 engine using a JDM H22 ECU??
Can I hook up my H22 ECU so that I can drive my car around for a few days until I have my H22 installed?? The reason why I ask is because someone wants to buy my H23 ECU VERY SOON!!
Old Dec 23, 2003 | 08:38 PM
LudeyKrus's Avatar
who? you bastard! I can't GIVE my H23 ecu away!
I would just try it and see
Old Dec 24, 2003 | 01:14 AM
Zimmlude's Avatar
It will prolly throw a code if you go above 5500 rpms as it will not see the proper sensors.
Also, it will have a higher fuel cut and prolly make you run a little lean.
Short answer, yes but don't go above 5500 and don't run it for too long.
Old Dec 24, 2003 | 01:30 AM
OTT's Avatar
OTT
It will defo throw a code or two but I doubt it will work without some major headaches!
Old Dec 24, 2003 | 06:56 AM
thehondaguru's Avatar
Default Re: (OTT)
It would work but I dont know how it would run
Old Dec 24, 2003 | 08:02 AM
SpoonREVS's Avatar
Default Re: (95 lude)
but what happens when the ecu tells the engine to kick in the vtec? or the sensor aint sending signal? i think you shouldnt do it it might **** up the engine..
Old Dec 24, 2003 | 08:57 AM
dankbudz11357's Avatar
Default Re: (SpoonREVS)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SpoonREVS &raquo;</TD></TR><TR><TD CLASS="quote">but what happens when the ecu tells the engine to kick in the vtec? or the sensor aint sending signal? i think you shouldnt do it it might **** up the engine.. </TD></TR></TABLE>
how would it if there's no equipment to engage the vtec. it would be like sending the signal to nowhere.
Old Dec 24, 2003 | 09:04 AM
AndyD's Avatar
Default Re: (Zimmlude)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Zimmlude &raquo;</TD></TR><TR><TD CLASS="quote">It will prolly throw a code if you go above 5500 rpms as it will not see the proper sensors.
Short answer, yes but don't go above 5500 and don't run it for too long.</TD></TR></TABLE>
LOL. I bet I have not take my car over 5500 20 times in my whole life outside of the track. I drive my car normally on the streets. lol
I am just looking to get my car from point A to point B for a few days.
If there is risk of messing up my H23 motor then I wont do it.
Thanks for the info.
ludecrasy87
Mar 14, 2007 10:27 PM
92LudeSI
Mar 29, 2005 04:45 PM
my9thtry
May 30, 2004 09:39 AM
NVSPRELUDE
Dec 9, 2002 10:54 PM
