Converted to OBD I what scanner do I use. OBD I or II
Old Dec 23, 2003 | 07:44 PM
turbo*s2k's Avatar
Default Converted to OBD I what scanner do I use. OBD I or II
I have a 2000 Honda Civic Si that I converted to OBD I. Today when I got a check engine light while driving I stopped by a friends shop so he could pull the code, because it turned off after I re-started the car. He was using an OBD II scanner, and it didn't work. Do I need to use an OBD I scanner now?
I'm using Si wiring harness with skunk 2 adapter harness with a P72 OBD I ecu
Thanks in advance!
Old Dec 23, 2003 | 08:27 PM
ljoe's Avatar
Default Re: Converted to OBD I what scanner do I use. OBD I or II (TurboChrgd_Civic)
yep, you need an obd1
Old Dec 23, 2003 | 09:49 PM
turbo*s2k's Avatar
Default Re: Converted to OBD I what scanner do I use. OBD I or II (ljoe)
Thanks!
Old Dec 23, 2003 | 09:52 PM
turbo*s2k's Avatar
Aren't there scanners that can read both OBD I & OBD II?
Old Dec 24, 2003 | 07:32 AM
ljoe's Avatar
it would seem that there would be, just hit a button to change the program or sumthin, although i've never seen one
Old Dec 24, 2003 | 08:17 AM
RyanEJ8's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TurboChrgd_Civic &raquo;</TD></TR><TR><TD CLASS="quote">Aren't there scanners that can read both OBD I & OBD II?</TD></TR></TABLE>
I think Snap On makes one. Very expensive though.
kiDchaos
Southeast (Sales)
Nov 9, 2013 12:55 PM
kiDchaos
Northeast (Sales)
Nov 9, 2013 12:54 PM
