Weird RPM problems ( not ignitor )
Old Dec 23, 2003 | 05:53 PM
StupidSlowRSX's Avatar
Default Weird RPM problems ( not ignitor )
Well, today i replaced my distributor in hopes of fixing this jumping tach problem.. nope.. didnt work.. then i moved on and replaced my plugs and wires... i still have this bounce in my tach.. ive checked all my grounds and cleaned them all as well.. Ive even tried another ECU (pm6) and it still goofs up =-[... wwhat else can it be?!?
btw...
89 DX with ZC
Old Dec 23, 2003 | 06:17 PM
onePOINTsix's Avatar
Default Re: Weird RPM problems (StupidSlowCRX)
stock tach or aftermarket? Stock tachs are shitty and unacurate, so it could just be going bad, if its a aftermarket "Rice Bowl" then check your RPM pickup wire, make sure it's connected as close to the distributer as possible. also check that you have it set for a 4 cyl. car
Old Dec 24, 2003 | 02:12 AM
my tach just doesnt bounce on its own... when my gauge reads tha i just dropped 500 RPM.. i can hear the engine drop 500 RPM.. Its not the tach..
hondacivic90zc
12
Jul 3, 2009 08:57 AM
AMChev
Nov 1, 2005 05:49 AM
WhiteGSR95
Mar 29, 2005 08:11 AM
OneThirtyEight
Jan 10, 2005 06:05 AM
Mantis88ls
May 23, 2004 09:13 PM
