need some major help quick as possible plz
Old Dec 23, 2003 | 05:22 PM
MysticSpade's Avatar
Default need some major help quick as possible plz
ok can anyone tell what the fuse under the hood goes to.
there's 5 fuses i need to know what the 4th one operates. i can't find the info anywhere. it's not even in any of the tear down books.
any help here would be greatly appreciated. if i can figure out what that fuse goes to i can have my ride out on the rode in an hour or so.
Old Dec 23, 2003 | 06:04 PM
onePOINTsix's Avatar
Default Re: need some major help quick as possible plz (MysticSpade)
hold up i'll see if i have a pic
Old Dec 23, 2003 | 06:07 PM
Default Re: need some major help quick as possible plz (Sideout)
are you talking about this box?
Old Dec 23, 2003 | 06:10 PM
if so...
34: Hazered Lights
35: Horn, Brake lights
36: Rear Window Defoger
37: Main Relay
38: AC Clutch, AC condensor fan
Old Dec 23, 2003 | 06:31 PM
YES!!
that's it thx for the pic
#37 Main Relay is the one but what is it the main relay of.
i know i sound dumb...but i need to know.
Old Dec 23, 2003 | 06:41 PM
the main relay controls the fuel injection system, if the fuse is bad replace it, if the main relay is bad goto your local NAPA and see if they have one in stock, sould be from $10-$20
edit: thats just the fuse for the main relay, run a quick arcive search for replacing it
Old Dec 23, 2003 | 08:01 PM
Caleb V's Avatar
Pop cover off of main relay and resolder connecttions on board, tiny hairline cracks occur around each one of the pins that pass through the circuit board due to vibration and heat. That will fix it 99.9% of the time, no need to buy another one. It is underneath your change box, remove change box and bolt that hold lower dash to A-pillar, you should have enough room to work with then to pry dash out of the way and get a 10mm socket or wrench in there to free it from it's lare. It's about 2"x2"x4" black rectangular box mounted to a metal tab that is bolted to the A-pillar. 8 pin connector on the bottom of it, controls ecu power as well as fuel pump on the other side of it.
shwanC
15
Dec 4, 2013 12:31 PM
jayzeno
Aug 21, 2011 07:30 PM
Juniorhatch
Acura TL, RL & ZDX
Apr 21, 2010 06:58 PM
