Brakes for my ReX
Old Dec 23, 2003 | 04:55 PM
'91 CRX CornerCarver's Avatar
Default Brakes for my ReX
I want to swap brakes from a '90 to '93 teg on my '91 Rex. How do i do this? Can i just slide on the rotors and bolt on the calipers or can i use the whole hub assembly with or w/o the control arms? should i use the teg master cylinder?
Old Dec 23, 2003 | 05:07 PM
EL Vap133's Avatar
Default Re: Brakes for my ReX ('91 CRX CornerCarver)
Hope this helps: http://tjshondas.20m.com/xlfronts.htm
Old Dec 23, 2003 | 06:22 PM
Default Re: Brakes for my ReX (EL Vap133)
great link, but what about the back? i couldn't find it.
Old Dec 23, 2003 | 07:04 PM
Alan Wil's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by '91 CRX CornerCarver &raquo;</TD></TR><TR><TD CLASS="quote">great link, but what about the back? i couldn't find it.</TD></TR></TABLE>
There is allot of misinformation on this subject on the front brake upgrade.
You use the whole hub assembly (AKA "the steering kunckles")
FYI: The above link says not to use the Integra kunckles, persons here on this board say they CAN be used successfully.
Try here:
https://honda-tech.com/zerothread?id=668258&page==
So far as info on the rear disc upgrade that info is everywere on the net.
Wish I had a link for you, looked but couldn't find it.
One last thing, when you get the car aligned POST the results of the alignment. If you can run the car by for a alignmnet "check" (Free at most places)... Then swap the Integra parts on for the final alignment.
POST your specs, and impressions here: https://honda-tech.com/zerothread?id=668258&page==
Best of luck,
EFMAN
11
Mar 6, 2005 05:09 PM
fatboyslim44
Sep 5, 2004 10:12 PM
hatchlessrex
Jan 21, 2004 10:17 PM
Dec 27, 2003 02:59 PM
blackturtle916
Oct 23, 2002 01:42 PM
