spark plug gap
Old Dec 23, 2003 | 04:48 PM
ITRswapandslow's Avatar
Default spark plug gap
ok, i did a little searching and really turned up nothing at all...
i have a JDM ITR engine in my car..and i'm swapping out plugs for an upcoming dyno/cam install/comparions test.
i got some 3924's....and just don't knwo what to gap them at...
i have 11.1:1...........................
some say .051, some say .045..and yet others say .035...so which is it?
stock ignition
Old Dec 24, 2003 | 01:26 AM
@ries's Avatar
Default Re: spark plug gap (ITRswapandslow)
I'd say start at .040 and work your way down if you notice any mis-fire
Also try using an NGK ZFR7F-11 or a BKR7E if you can
Old Dec 24, 2003 | 03:06 AM
00 FBP ItR's Avatar
Default Re: spark plug gap (emoBB1)
.038
Old Dec 24, 2003 | 07:48 AM
for my low compression, i just stuck it at .40
does really well, and feels much smoother
Old Dec 24, 2003 | 11:23 AM
emissionsux's Avatar
So JDM ITRs are supposed to have a 7 heat index?
Old Dec 24, 2003 | 12:13 PM
Suprdave's Avatar
Default Re: spark plug gap (emissionsux)
There is alot of trail\error with spark plugs.
You could start with a 1.1mm Pre-Gap and work down if any mis-firing.
Suprdave
Old Dec 24, 2003 | 01:09 PM
we MIGHT play with gap on the dyno, if we have some spare time on hand. But i'm pretty sure it's been solved allready for when i get the next bottom end.
thanks guys
gsr96cx
Jul 17, 2008 07:21 PM
99hondacura
Sep 23, 2007 06:37 AM
123Four
Sep 22, 2007 03:28 PM
xintegr
Mar 13, 2005 01:03 PM
pa2play
Jul 25, 2004 01:15 PM
