Honda Alignment "Crash Kit"?
Old Dec 23, 2003 | 01:57 PM
LightFoot's Avatar
Default Honda Alignment "Crash Kit"?
Does Honda supply an alignment "crash kit" [bolts, plates, etc.] that allows
caster and camber alignment to be achieved after a car has been in a "crash"
that has slightly bent the car/frame? How about for my '85 CRX Si?
Thanks in advance
Old Dec 23, 2003 | 03:37 PM
jc836's Avatar
Default Re: Honda Alignment "Crash Kit"? (LightFoot)
NO. The best thing you can do is spend ~$200 on a frame machine and have them pull it back into spec. for starters. If you need suspension parts they can also tell you that. There is no such thing as slightly bent, btw. for the purpose of trying to realign the car. There are parts that can help with Camber and Caster on some models and not others. Generally a torsion bar setup is not as simple as a wishbone/coil spring type.
Good luck and happy holidays
njl481
Suspension & Brakes
Feb 24, 2012 12:11 PM
nastyARE
Suspension & Brakes
Dec 26, 2009 03:24 AM
TylerC161
Aug 27, 2007 11:02 AM
ucd_4_life
Jan 31, 2006 04:15 PM
ef8mugen
Oct 28, 2003 04:05 PM
