B16 head better than B18C1? (SI over GSR)
Old Dec 23, 2003 | 01:39 PM
KB96VTEC's Avatar
Default B16 head better than B18C1? (SI over GSR)
a local guy in town boosted a hatch with a GSR block and B16 head. he told me the B16 head was better than the GSR head but didnt get into details. anyone care to explain this to me?
Old Dec 23, 2003 | 01:46 PM
Drag_Racer_DRU's Avatar
Default Re: B16 head better than B18C1? (KB96VTEC)
it flows better, its close to a type R head if you were to port the bowls (pocket port)
Old Dec 23, 2003 | 03:32 PM
hispanic panic's Avatar
^^ your talking about the ctr head. the ctr head is the same as the itr head except the itr head has a factory port and polish. The gsr head flows about 5% less than an itr or ctr head but it has a "square" shaped chamber which in turn increases compression. I don't know much about b16a heads, but they are similar to the b16b heads. For all engine purposes, the itr head is still better. for forced induction applications the itr is even still the better head because of its increased flow. I guess you could consider the b18c5 head the "rennisance" head
Old Dec 23, 2003 | 03:34 PM
i think he used the b16 head because it lowered compression a bit and made running boost a lil more safe
Old Dec 23, 2003 | 08:40 PM
99blackcivicSi's Avatar
Default Re: (hispanic panic)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hispanic panic &raquo;</TD></TR><TR><TD CLASS="quote">itr head has a factory port and polish</TD></TR></TABLE>
I wouldn't call that a port and polish i would call it smoothing. Too much money for soo little gain
Old Dec 23, 2003 | 10:37 PM
Propulsion's Avatar
Default Re: (99blackcivicSi)
go the the alaniz site to see the flow chart. THere really isn't much difference at all, but the gsr flows a bit better at mid-lift, and b16's better at high lift. Again, only negligible differences. gsr will give you about .2 more compression though.
Old Dec 24, 2003 | 10:28 AM
^^ true dat
Old Dec 24, 2003 | 10:34 AM
I prefer the B16 head minus the cams they suck . All of the intake manis i have are for B16 and Type R bolt pattern.
Old Dec 24, 2003 | 11:24 AM
Kendall's Avatar
The combustion chamber design of the B16 promotes more complete combustion when compared to the B18, but not by much. They flow similarly, but the B18 does increase the compression. It's all in what your goals are. For example you'd probably want the B16 head if you were running high boost.
Old Dec 24, 2003 | 02:18 PM
HEAD's Avatar
Default Re: (dc231)
it's been my experience that the B18 head will **** all over a B16 head in the making big power department, especially in a boosted or NOS app. everyone in the Hot Rod class runs it which should tell you something. one thing I like is the placement of the injector in the B18
Old Dec 24, 2003 | 02:36 PM
Kendall's Avatar
That is a very good point. One serious advantage of the B18 head is it's ability to create good combustion when combined with flatter pistons, something probably common in the Hot Rod class. by using a high compression flat piston you're getting almost perfect combustion when compared to a domed piston in a B16 head. The simple fact that the B18 head give you higher compression makes this combination possible. There are too many variables to consider when trying to compare the two, so best advice: use what works for you.
HEAD, get in touch with me sometime. I may be needing some headwork in the near future.
Old Dec 24, 2003 | 10:47 PM
LudeyKrus's Avatar
in a nutshell, the B16 has the best flow potential of the B-series heads. It outflows the B18c1 head, and most p&p'rs won't port out the ITR head b/c it's already ported the wrong way from the factory (or something to that effect; it has too much material taken out from the bowls, so they can't really do much w/ them)
Old Dec 25, 2003 | 07:00 PM
just get yourself a ctr or itr cam, they are hbte best of the best
flow the best and wil give you a good efficient combustion
Sep 14, 2006 07:26 AM
hialeahzbg
16
Aug 1, 2006 10:57 PM
Viorent Grip! EG
Dec 21, 2005 11:12 AM
gooknom
Apr 25, 2004 11:30 PM
S@nt0s
Jan 17, 2004 08:19 PM
