My motor has a very loud tick...
Old Dec 23, 2003 | 01:13 PM
B18EG6's Avatar
Default My motor has a very loud tick...
Hey-
This is just a question to gather some opinions... A while ago my motor had a very light tick at certain RPM's, and would disappear as the RPMs increased. I took it for a spin the other night and the sound got progressively worse, to the point where its louder than the exhast at idle
The timing belt has nice tension, and I havent had a chance to check the valve clearances yet... The turbo has no shaft play. Another note, upon startup the noise will occur, and disappear slightly when the oil light turns off.
Any ideas? I wont be around my car for a while so im just gathering some opinions to see what it might be.. but as of right now im thinkin the valves need to be adjusted (but i just did a valve adjustment maybe a few months ago )
whatcha think?
Old Dec 23, 2003 | 01:33 PM
RCautoworks's Avatar
Default Re: My motor has a very loud tick... (B18EG6)
What motor are you running ? It might be the valves but it might be the lma's
Old Dec 23, 2003 | 01:51 PM
b20turbojason's Avatar
my buddy swapped a motor into his car and it was making a loud ticking that got louder and it ended up being the oil pump. just an idea. from my experences
Old Dec 23, 2003 | 03:10 PM
B18EG6's Avatar
Default Re: My motor has a very loud tick... (b20turbojason)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote &raquo;</TD></TR><TR><TD CLASS="quote">What motor are you running ? It might be the valves but it might be the lma's</TD></TR></TABLE>
gsr motor. I had my mechanic help me with the valve adjustment not too long ago... the ticking got loud over the course of about 5 minutes after hard acceleration, not over an extended period of time.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by b20turbojason &raquo;</TD></TR><TR><TD CLASS="quote">my buddy swapped a motor into his car and it was making a loud ticking that got louder and it ended up being the oil pump. just an idea. from my experences</TD></TR></TABLE>
Hmmm.... funny you say that, not too long ago I had my oil light come on at idle. I replaced the main bearings and put a new oil pump in. What are some things I can do to check further symptoms? The ticking is so loud and violent I can feel it in the gas pedal. When i accelerate slightly it ticks, and then wheni let off the gas it gives a lil more of a tick till the rpms fall.
Does that help?
Old Dec 23, 2003 | 03:42 PM
mattssi's Avatar
It is possible that one of the 10mm bolts that hold your valve in place didn't get tight enough? And maybe the valve slipped?
Old Dec 23, 2003 | 07:01 PM
Mohudsolo's Avatar
Default Re: My motor has a very loud tick... (mattssi)
Rod bearing or wrist pin retaining clip? Possible exhaust leak? A header to head exhaust leak can make a sharp tick.
Old Dec 23, 2003 | 07:17 PM
Jim Truett's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B18EG6 &raquo;</TD></TR><TR><TD CLASS="quote"> Another note, upon startup the noise will occur, and disappear slightly when the oil light turns off.
If you actually have enough time to listen to the pinging before the oil light goes out, I say you have a problem. Either the main and rod bearings are worn, or your oil pump is worn. Install an oil pressure gauge and compare the readings to the stock specs.
Old Dec 24, 2003 | 06:35 AM
Default Re: My motor has a very loud tick... (Jim Truett)
like the other guys sounds maybe like rod bearings. but it is hard to tell with not being in front of the car. did you change the rod bearings when you replaced the main bearings.
Old Dec 24, 2003 | 09:14 AM
B18EG6's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by b20turbojason &raquo;</TD></TR><TR><TD CLASS="quote">like the other guys sounds maybe like rod bearings. but it is hard to tell with not being in front of the car. did you change the rod bearings when you replaced the main bearings. </TD></TR></TABLE>
no i didnt change the rod bearings my mechanic said it wasnt needed The main bearings and oil pump were replaced not even 1000 miles ago.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote &raquo;</TD></TR><TR><TD CLASS="quote">If you actually have enough time to listen to the pinging before the oil light goes out, I say you have a problem. Either the main and rod bearings are worn, or your oil pump is worn. Install an oil pressure gauge and compare the readings to the stock specs.</TD></TR></TABLE>
Good advice about the oil pressure gauge... My oil pump only has about 1000 miles on it, while the rod bearings have about 100,000 miles on them.
If you want i can record that noise when i go home and upload it Id check the valve clearnaces but like i said im not home right now... My educated guess would point to the rod bearings right now... seeing as how a qualified mechanic did my valve clearances for me.
oh well... gimme an excuse to rip my motor out and fix the fockin thing for once.
Old Dec 25, 2003 | 08:07 AM
B18EG6's Avatar
put it up there one more time before i see my car again
Old Dec 28, 2003 | 08:34 PM
BauleyCivic's Avatar
Risky Business
Long shot...but does it go away when you press your clutch in?
Old Dec 28, 2003 | 08:41 PM
Erik_Pb_Foot's Avatar
New User
Default Re: My motor has a very loud tick... (BauleyCivic)
install the oil pressure gauge... get a cheap lil autozone mechanical one, it doesn't matter unless you just want to get a nice one and keep it mounted in the car. that will help you start to eliminate things. i wouldn't let it go neglected though...
Old Dec 28, 2003 | 11:01 PM
99spanishGT
Guest
Posts: n/a
Default Re: My motor has a very loud tick... (Erik_Pb_Foot)
ok first can you fell it in the clutch petal if so i would say main or rod bearing, my h23 had the same thing
and second does it kinda sluggesh on the start up?
Old Dec 28, 2003 | 11:20 PM
K20EG's Avatar
you may have a stretched rod...the noise could be the piston hitting the head
Old Dec 29, 2003 | 01:41 PM
B18EG6's Avatar
Default Re: My motor has a very loud tick... (spanishlude)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by spanishlude &raquo;</TD></TR><TR><TD CLASS="quote">ok first can you fell it in the clutch petal if so i would say main or rod bearing, my h23 had the same thing
and second does it kinda sluggesh on the start up?</TD></TR></TABLE>
Well i can feel it in the gas pedal when im driving, almost feels like something is tapping on the firewall!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote &raquo;</TD></TR><TR><TD CLASS="quote">install the oil pressure gauge... get a cheap lil autozone mechanical one, it doesn't matter unless you just want to get a nice one and keep it mounted in the car. that will help you start to eliminate things. i wouldn't let it go neglected though...
good idea... what should i look for? just the general oil pressure? Do you think its alright to let the car idle when its tapping?
My dads car makes almost the exact same noise... except his is a LOT quiter, and disappears after its warm.
Old Dec 29, 2003 | 04:14 PM
Risky Business
Seb...does it go away when you press the clutch in?
Old Dec 29, 2003 | 04:21 PM
K20EG's Avatar
from what you explained i would go through all the valve adjustments make sure everything is right on
Old Dec 29, 2003 | 05:23 PM
B18EG6's Avatar
Default Re: My motor has a very loud tick... (K20EG)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote &raquo;</TD></TR><TR><TD CLASS="quote">Seb...does it go away when you press the clutch in?</TD></TR></TABLE>
i mean... if i free rev i still hear it
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by K20EG &raquo;</TD></TR><TR><TD CLASS="quote">from what you explained i would go through all the valve adjustments make sure everything is right on</TD></TR></TABLE>
ok ill do that... whats the specs again .006? .007? thanks
Old Dec 29, 2003 | 05:29 PM
K20EG's Avatar
6 and 8
Old Dec 29, 2003 | 08:38 PM
CleenSi
Guest
Posts: n/a
Default Re: My motor has a very loud tick... (90blackcrx)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 90blackcrx &raquo;</TD></TR><TR><TD CLASS="quote">What motor are you running ? It might be the VALVES but it might be the lma's</TD></TR></TABLE>
Old Dec 29, 2003 | 11:03 PM
EKsite's Avatar
From my personal experience it sounds like it could be your LMA, mine are shot and sound exactly like how you described it. Upon start up its REALLY loud, then as oil circulates to the head they keep on clicking away just not as bad. Hope this helps!
Old Dec 30, 2003 | 12:42 PM
B18EG6's Avatar
Default Re: (EKsite)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EKsite &raquo;</TD></TR><TR><TD CLASS="quote">From my personal experience it sounds like it could be your LMA, mine are shot and sound exactly like how you described it. Upon start up its REALLY loud, then as oil circulates to the head they keep on clicking away just not as bad. Hope this helps!</TD></TR></TABLE>
Hmmm.... would the problem jump from quiet to loud over the course of 5 minutes? They were real quiet and then after a race they got amazingly loud. Ill check the clearnaces soon, how should I check the LMAs? just push down on them?
Old Dec 30, 2003 | 02:20 PM
Hmmm.... would the problem jump from quiet to loud over the course of 5 minutes? They were real quiet and then after a race they got amazingly loud. Ill check the clearnaces soon, how should I check the LMAs? just push down on them?</TD></TR></TABLE>
If you would of read the 1st reply you might already of been done with this.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 90blackcrx &raquo;</TD></TR><TR><TD CLASS="quote">What motor are you running ? It might be the valves but it might be the lma's</TD></TR></TABLE>
Anyways does the sound go away when your racing or hit higher oil pressures. The lma's will stop making noise when oil pressure increase but will start making noises when oil pressure drops. Or press down on the vtec lobe rocker arm. It should move freely and spring back, if it sticks then you should replace them.
Old Dec 30, 2003 | 09:23 PM
99spanishGT
Guest
Posts: n/a
Default Re: (90blackcrx)
pull your oil filter off and chech it for metal shavings
Old Jan 2, 2004 | 04:36 PM
payneth's Avatar
**** the same noise happened to my old car for th elognest time at 3,000rpm. and i hated every minute of it! couldnt go past 55mph, shitty *** old car
EJ8_Man
May 4, 2016 09:26 PM
spankey167
23
Jan 12, 2005 11:13 PM
918-Hatch
10
Nov 10, 2004 03:10 PM
Electron Blue Blur
12
Jun 29, 2004 03:06 PM
B18C1 '96 Coupe
Dec 30, 2002 09:33 AM
