help!!! head light unit..
hey guys
I need some help here..
I own 03 Accord 4dr sedan and I need to know
how to remove the headlight housing from the car..
does anybody know how? or any website that I can look at?
thanx
thanx
I don't have an accord, but with my Prelude, I just stuck them into the oven at 300 degrees and checked them every 5 min. until I was able to pry them apart. It takes awhile, so be careful when doing this.
Products used:
-Oven
-Foil/cooking sheet
-Flat head screw driver
-Patience
Products used:
-Oven
-Foil/cooking sheet
-Patience
first, remove the bumper... you'll need to remove 2 tabs from the top, 6 tabs (i think) from the bottom, and 1 screw from each of the fender wells. after that, you'll see a bar under each of the headlight assemblies, held on by 3 bolts. remove the 3 bolts, and the bar. remove the bolt above the headlight assembly as well. after that, you should be able to pull the headlight assembly off, but sometimes you may need a little force to do so.
you properly doesnt need help removing the bumper cover, it's a piece of cake just look for screws and take them out.
search for paint/housing/headlight/etc
picture, video, you names it..
wekiser
31
Mar 29, 2010 11:57 PM
waggontrainer
Lighting
Jun 5, 2008 03:26 PM
trimagna
Aug 31, 2007 07:23 PM
badassaccord
Sep 26, 2002 05:20 AM
